Question about Philips 43PP9202 43" Rear Projection Television
My tv turns on and right off.
Do I need to change the IC's if so where are they located?
Thanks
  • Philips Master
  • 8,617 Answers
They are located on the board on the left mounted to a large aluminum heat sink. They are STK392-120 you need to replace both of them. You can get replacements at the following link and they provide free instructions with pics so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 07, 2008
My tv is changing channels it self
The memory IC to your TV is faulty. Check and replace it. This is an eight solder terminal IC, can be located very near to main system control IC. Even though physical size to this IC is so small, function to it in circuit, when the TV works is great. You must have thofough knowledge in electronics to do this work, because, you might have to enter its service mode option to do some adjustments. This work is very skilled one, as service mode option window, and normal user window are entirely different to each other. Adjusting wrong data value to service mode options might make the TV irreparable, and irresponsive.
Jul 04, 2012 | Televison & Video
Rca p61927 no sound with tv remote nor volume button on tv
First you have to check that the button-internal external speakers are in the right place, that's in the back of the TV. If there is still the problem, the audio output is faulty. Need to change audio IC. Perhaps you need technical assistance, that is a bit difficult to change IC. If you have further questions, do not hesitate I'm here to help. thanks
Aug 13, 2011 | RCA P61927 61" Rear Projection Television
Tv will not turn on. when plugged in there is a beep beep beep.
does it back up while beeping? just kidding - what does the power light on the tv do after you try to turn it on do you hear sound at all? have you tried changing inputs (do you get video on any input) does you see a picture n the tv at all if so is the picture really dark - need a little more info to get you in the right area - probably a power supply or inverter board problem to be honestly with you.
thanks,
michael
Feb 25, 2011 | Proscan PS32500 32" TV
Hi I accidentaly actiivate the child control on my tv and turned it off, I don't have the original remote any longer and I can not turn on my tv. Please help Mike
Concerning the problem...it is extremely likely that you have a corrupt EEPROM. A very common problem with this TV.The correct EEPROM (IC location IC 002) is dependent on which microprocessor (IC location IC001) and which stereo decoder (IC location IC 1001) are present on the board being repaired. Take this info to a TV tech and they will find the correct EEPROM to replace. Your TV will come back to life. If not, give me the numbers of ICs IC001 and IC1001. I will forward the correct EEPROM part #. Then the tech will repair your TV. Thanks for asking and show all hands of support!
Dec 01, 2010 | Philips Magnavox 27MS343S 27" TV
My Magnavox tv is about 5 years old. When we turn it on the screen is blank. A soft high pitched sound comes out of it. The green "on" light blinks on and off. Any ideas on what is happening and why it...
You have a bad eeprom. Very common problem for this TV. The replacement eeprom [location, IC002, on the Tv board] is dependent on which microprocessor [location, IC001, on the TV board] and which stereo decoder [IC 1001] are present on the board. See if IC002 has a color mark on it. red, yellow, green..etc. Or give me the numbers on the actual IC 001 and Ic1001. For example IC 001[ microprocessor] might beMCU A22V01-TO and IC 1001 [stereo decoder] MSP3440. Take this info to a TV tech if you cannot repair this TV yourself. Thanks for asking and give me a High Five of hands!
Sep 14, 2010 | Philips Magnavox 27MS343S 27" TV
I have a sony kv36fs200 its about 8 yrs old. the set takes about 20 min to come on . picture is perfect. do not hear the degaussing coil activate when it eventually powers up . first it was flashing 5...
TV needs screen volts adjustment, screen volt control knob is located on flyback transformer.
Turn On tv and rotate screen volt (G2) control knob clockwise little bit to increase volts to get picture. This problem related with picture tube as its performance seems weak and causing problem.
Aug 17, 2010 | Sony KV-36FS200 36" TV
TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
Mar 03, 2010 | Apex Digital PF2025 20" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
TV turns off right away relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
