Question about GE WSXH208A Front Load Washer
GE Front Load washer problem
My GE front load washer is about 5 years old. It recently started to fill up with water long after the cycle was complete. I have to use the drain cycle to drain the water out. Does anyone know what the problem could be?
    Genius:
  • 1,073 Answers
Replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Posted on Apr 28, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Water left in washer
You must change new pump.
Feb 15, 2009 | GE WSXH208A Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Whirlpool LHW0050PQ Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
239 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
