Question about Samsung HCM4216W 42" Rear Projection Television
HCM4216W won't turn.....?
HCM4216W won't turn on the red timer light blinks but there is no sign of life......?? Could it be the Convergence Board...???
  • rwindeler May 03, 2008
    Same here. Same exact set. Just happened. Set quit while it was on. I smell smoke. Please email me at dot_calm@hotmail.com if you find a solution.
  • Anonymous Jul 13, 2008
    Same here. I unplugged the power cable for 1 day. Turn it on, it actually works for a while, then the same problem again.
premtech
  • 934 Answers
SOURCE: Samsung HCM4216W Power Problem
Vern,
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps!
Bill
Posted on Dec 10, 2007
  • 346 Answers
SOURCE: HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Posted on Dec 27, 2007
SOURCE: samsung hcm4216w
Hope this helps
Posted on Jan 19, 2008
premtech
  • 934 Answers
SOURCE: red blinking light
It's most likely convergence -- the small board up and to the right inside the back of the TV, which has two large amp Ic's attached to it..
Unplug the +/- 20v line on the fron left corner of that board (red in color) and then try and power on the set... If the set comes on the board needs to be repaired and it's an easy unplug and two screws that mount it inside.
Bill
Premium Technologies
PO Box 442
LOng Beach, WA. 98631
360-641-4993
premtech@willapabay.org
Posted on Jun 15, 2008
SD Tech
  • 14553 Answers
SOURCE: HCM4216W...replaced convergence board...still no
Do not take this the wrong way--I have seen several people make this kind of mistake--why on earth replace the board when you can buy the pair of chips for under 15 dollars?
At worst--there will be other than the chips a fuse on the board near them bad...
Look at the old board if you have it--this model should use STK-392-040 chips--I can tell you a seller who has them on EBAY---my point is these sets it is almost always better to just replace the chips and fuses if needed--
Do you have the old board? Can you return the new one for a refund?
I have repaired hundreds of sets with convergence problems and only a very few needed to have the board replaced.
I understand why this happens--people think it is easier to replace a board but they are wrong--it always costs more that way and presents problems.
Give me as much info as you can and those chips are readily available. I can tell you name of the seller I buy mine from--got several of the chips your set uses on hand right now.
If this helps you rate this solution as I do this here for free.
If you have questions or need any help ask me--I am here to help.
Posted on Dec 24, 2009
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Red and Blue convergence issues cause triple-image
This sounds like your convergence chip is bad. If you are good at soldering you can order the replacement kit from www.tvrepairkits.com and do it yourself.
Apr 17, 2009 | Samsung HCM4216W 42" Rear Projection...
Timer Light.
according to the book hcm4216w says ti will blink 10 times when turned on then then iluminate when on
Jul 20, 2008 | Samsung HCM4216W 42" Rear Projection...
Red blinking light
Bill
PO Box 442
360-641-4993
Apr 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung hcm4216w
Hope this helps
Jan 09, 2008 | Samsung HCM4216W 42" Rear Projection...
SAMSUNG HCM4216W has a verical line
the vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Dec 07, 2007 | Samsung HCM4216W 42" Rear Projection...
Vern,
Hope this helps!
Bill
Mar 05, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
78 people viewed this question
Henry  Thomas
Henry Thomas
