Try first unplugging power cord, pulling out cartridges, and putting them back.
Restart the computer.
Ensure you removed the cellotape strip from new cartridges, and that cartridges are properly installed.
Ensure that the printer is set as default printer in Windows.
Print a test page from control panel>>printers>>properties.
If
all the above does not work, try a replacement USB cable, just in case,
then proceed reinstalling the driver software. Follow the method below
to reinstall software:
To reinstall the software you can use the disk that came with the printer, or download the driver software:
Click here:
Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe
file, double click on the file , then if you getintroubles,followthe
instructions below to reset and reinstall drivers:
- Unplug printer USB.
- Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
- Download driver from website, or use the disk and run the install file.
- Follow driver installation wizard.
- Plug back printer when prompted from installation wizard.
