I've just got a Maxtor OneTouch4 external hard drive - how do I protect it with a password ? Txs
    Problem Solver:
  • 5 Answers
You will have to download and install an application like Cryptainer LE Free Encryption Software 6.0.1. Windows 2000, XP, and Vista don't password protect individual folders.
Posted on Apr 28, 2008
Pls i need a maxtor onetouch4 mini safety drill recovery disc
Hi, You can download it here:-
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-safety-drill&vgnextoid=104c7fe050744110VgnVCM100000f5ee0a0aRCRD
"Once downloaded, you can use a third-party CD Burning Application to create (burn) a new, SafetyDrill CD in the event that the original CD becomes damaged, lost or corrupted."
Dec 20, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My Onetouch4 Maxtor external experienced a hit and afterward it sounds a repeatitive beep when pluged into the electricity? wht should i do? tnx in advance
If you're lucky the damage is only in the enclosure circuitry, take the drive to your local PC shop and ask the techs to test the HDD inside in a new enclosure. If it works you can simply buy the new enclosure and be on your way. If it fails the failure is in the HDD itself and you will require the help of a pro. If you need a pro, reply with your location(Country, State and City) and I can direct you to a nearby facility that will be able to assist you with data recovery.
Hope this helps FixYa,
Chris
Sep 29, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
I have a Maxtor 80GB external hardrive and I can't get into it. I have checked all the plug connections, shut the computer off and rebooted. The short cut to my photos on my desktop has also disapeared and...
Flashing light shows that your pc is comunicating with the drive, so it is posible that it is damaged, is the disc ide or sata, try conecitg it directley on the motherboard like a slave disc.
Sep 01, 2009 | Maxtor Computers & Internet
After windows re-install, locked out of Maxtor drive
Sounds like you're on the right track, but you don't need to buy another drive to get the software. Go to the link below and find the download for your drive in the list.
The software downloads are a free form of support from Maxtor.
http://www.seagate.com/www/en-us/support/downloads/
If you have trouble or this doesn't work then post back here and I'll see what else we can do to help.
Chris
Aug 20, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor manager software shows no drives
First and foremost if you're getting power but not seeing the drive you likely have either a drive or enclosure circuitry failure.
If you have no power lights try a new power adapter.
If the drive has failed and you want the data back you will need a Data Recovery Pro to asist you, if the enclosure has failed it will be much simpler.
Step one take the drive enclosure to a PC shop(no offence to Mac techs but they stink at salvage efforts, must be too many years of promising nothing ever fails ;)). When you get there ask them to remove the hard drive from your Maxtor enclosure and pop it into a generic enclosure(looks cheap but the internals are identical in most cases). Then ask them to test the drive to see if it shows up, depending on how you formatted it they may need MacDisk to make it visable.
If it works, buy the enclosure and head home, you're done. Plug it into your Mac and go on with your day, no harm no foul.
If this fails to see the drive, then the Hard Drive itself is likely at fault, in this case reply to me with your Country, State and City and I will refer you to the closest Data Recovery Facuility with Mac capabilities to have your data retrieved,
Of course if the only data on it is still accesible on the computer and it's a dead drive, just buy a new external, head home and rerun the backups manually as in this case it's cheaper to chuck and replace the external than have it recovered.
Chris
Aug 05, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
HOW do i Maxtor OneTouch4 500GB External Hard Drive Format
Go to My Computer, right click on the Maxtor OneTouch harddrive, select format, check quick format, click format.
Apr 26, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
If this is a Maxtor drive that you password protected and now you can't get it to work on another PC or new hard drive. I had the same problem. Fortunatly I had set it up on another PC prior to setting up password protection, so when I tried it at work I discovered that the software will not even load on the PC becuase of the Password protection. If possible you need to use the hard drive that it was first set up and turn off the password protection. Then it should work on any PC.
Nov 10, 2008 | Computers & Internet
I bought a Maxtor OneTouch4 Mini 160GB external hard drive. The rason being that I wanted to increase my hard drive capacity--My laptop is below 50 GBs now and I intend to be doing quite q lot of video...
I have a 320GB Maxtor OneTouch. I copied all of the software off of the Maxtor to my main drive then reformatted the Maxtor as a normal driv.
Lou
Aug 24, 2008 | Computers & Internet
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Drive Not Read By ANY Computer
Before installing the Maxtor drive you need to take a backup of the software on the Maxtor. You then need to burn this s/w to a cd to allow you to install the s/w onto any Mac (or PC) you want to use the Maxtor with. If you don't enable the encripted mode then you don't have this problem.
If you didn't take a backup before starting then have a look on the Maxtor site for the correct s/w.
Cheers, robbo
Nov 14, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
