Question about Dell 1600n All-In-One Laser Printer
MAINTENANCE KIT WHERE CAN I GET A MAINTENANCE KIT?
  • 1 more comment
  • YFJYF786T876 Apr 28, 2008
    DELL SUCKS ***
    BUY HP
    YOU CANT GET IT YOU HAVE TO BUY ALL THE ROLLER ONE AT A TIME AND THE PAPER TRAY YOU CANT GET IT YOU HAVE TO BUY THE ENTIRE TRAY AT 119.99 INSANE. BUY HP AT LEAST THEY SELL MAINTENANCE KITS
Where do you get the pick up rollers. My printer will not pick up the paper from the tray. It just says printer jam when we try to print.
Posted on Aug 08, 2008
    Genius:
  • Dell Master
  • 1,056 Answers
There is no maintenance kit per sey. To do a maintenance on these, you only need the fuser, and the 2 rollers in the ADF.
Total cost for all the parts is about $90
I've done these kits a number of times, and they run like new after. I've never had to change the pickup rollers in the drawer yet.
Posted on Jul 22, 2008
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
Install maintenance kit
The Maintenance kit is a supply you can order and replace without a technician. Look for a door on the right side of the machine toward the middle. Open it and remove a light orange assembly. This is the Maintenance Kit and is what needs replaced.
113R00736 Maintenance Kit, Standard
604K53810 Maintenance Kit, Extended
Apr 24, 2013 | Xerox Phaser 8860MFP/D - Multifunction -...
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
Xerox 8560 displays replace incorrect maintenance kit
Was this a new maintenance kit? If it was new, try putting the old one back in, if it reports the same message, the pivot plate will more than likely need replacing. If it displays the original message i.e, replace maintenance kit, then the fault is with the new maintenance kit. Do check you have been sent the correct maintenance kit for your machine, part number should be 108R00675 for standard and 108R00676 for the extended Phaser 8560 printer and Phaser 8560MFP kit.
If it is the original maintenance kit and the error just appeared, as I am assuming you will have already tried re-seating it, the problem is likely to be the pivot plate again.
Hope this helps.
Jan 22, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Maintanance kit replace
Problem:
Cause:
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Dell 1600n All-In-One Laser Printer Logo
437 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
