Question about Panasonic Lands Phones
I have a Panasonic Key Telephone system VA-61410. There was a power outage and hence the phone system did not reset upon power coming back up. I have turned the unit off and currently running throught the jack directly. Please advise and guide so that I may be able to use it for my business. Thanks Nash
Buffalo12980
  • 625 Answers
SOURCE: no electrical outlet available for the base station (wall mounted)
most cordless phones need some access to 120 volt power to recharge the internal NiCad batteries. It wouldn't be cost effective to have on hand a bunch of charged batteries that you'd replace on a daily basis. they got to be charged up eventually.
Posted on Aug 23, 2007
SOURCE: i forgot my password for panasonic
I FORGET PASSWORD OF DAIL LOCK FOR KX-TG2361JX
Posted on May 18, 2008
SOURCE: call forwarding
*72 +areacode & phone #
*73 to remove call forwarding
Posted on Oct 08, 2008
consultel1
  • 860 Answers
SOURCE: Where can I find the Business Telephone System for the Panasonic
Although it doesn't look like a lot of information in their guide, heres a link to Panasonic's manual:
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
Hope it helps.
Posted on Dec 21, 2009
  • 5 Answers
SOURCE: Urgent please (KX-TSC30BXW)
I HAVE THE SAME SYSTEM BUT I DONT THINK U CAN UNLOCK WITHOUT PASSWORD
Posted on Apr 05, 2010
What should the voltage measure on modelKXTG2632
Second phone power supply is connected to your first phone.
Hence the second phone works.
Dec 19, 2015 | Panasonic Lands Phones
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
I have a Panasonic PV DF205. After a recent power outage the tv will no longer operate. Is there a fuse that could be replaced or a reset switch?
It could be a fuse. But you need a tech to do it. Its not safe for you to poke around in there.
If you were near me, I'd check it out. Va Beach.
Aug 29, 2011 | Televison & Video
Panasonic KX-NT136 - how do you page directly to another extension and begin talking to the other person without them picking up?
It's not called page, it's INTERCOM. On the face of most Panasonic phones, there's a button labeled AUTO ANS. When you press it, it lights up. If the options are set properly, it becomes the Voice Announce/Auto Answer button. Every phone you want to have the VA feature on has to have that button lit. When you call them on the intercom, it will beep twice and your voice will be on the set and they may or may not be able to answer back handsfree.
It requires system programming and theere's a code you can dial to block it.
Carl
Mar 23, 2011 | Panasonic KX-NT136-B Hybrid IP Telephone -...
Our telephone and answering machine quit working after a power outage. Pushed reset button but nothing changed. The letter E is in the window of the base unit. When unplugged the power supply and...
it sounds like the unit has taken a surge, which is a common side effect of power outages. unplugging and replugging make fix the issue but since you have already tried this, i would reccomend contacting the manufacturer. See if a replacement can be given or if you have warranty on the unit.
The E is most likly a refrence to general error. the main board for teh unit was probably damaged by the power outage.
Mar 07, 2011 | Uniden EXAI 918 Cordless Phone
KXTD816 Panasonic telephone - lost phone connection
Good thing. You probably don't need to know. Try powering the system down, and power it back up. Watch the lights as it comes up.
Do you get a solid light on the lower right side of the cabinet? Now see if you can dial intercom to intercom calls. Press one of the line buttons and see if it lights up. If it does, I'd be looking for dial tone at the telco interface. Those are RJ-14 jacks (2 lines per plug).
P.S. The reset button you don't want to press is on the lower right side of the cabinet. If the switch is in the wrong place, you'll trash the memory.
May 31, 2010 | Panasonic Lands Phones
Panasonic phone system, won't release the phone line
You might try removing the battery pack and see if that resets the phone. If not, you probably have a component inside the phone that has failed.
On most cordless phones, it is not cost effective to have them repaired.
Oct 16, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Need to know if I can use a digital dial tone with this switch
A regular telephone will plug into the ATA from the cable modem. You just plug one of the ports of the phone system (CO port) into the same place and you'll get dial tone.
That VA-208 is REALLY old :-} What, about 20 years?
Carl
May 05, 2009 | Lands Phones
Voice mail outage
You can try unplugging the power supply and phone lines for a few minutes. Then reattach the phone lines and power up to re-boot.
Our Vodavi 5000-00 used to blink off during thunderstorms until it finally fried. This is how we used to reset it.
Oct 22, 2008 | Vodavi 30-Button XTS Telephone
Panasonic telephone system KX-TD816e
re:reset On the side of the cabinet near the power switch is a reset button and a SET CLEAR switch. Turn off the system, put the switch in CLEAR and push the reset button with a pointed tool. When the red light flashes and within 10 seconds, put the switch to SET.
I'm hoping you have a programming manual even though you must not have an installation manual.
Carl
Nov 22, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
57 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
