Schematic/manual needed for RCA 27V412T Color Television repair
I am attempting to repair this tv for a friend of mine that has no money to pay for repairs at a shop.
I find that there are NO loose connections, broken parts or bad solder joints.
There is no odor of something over-heating. A complete visual inspection has been done, as well as "TAP" tests looking for opens... none found.
Description of problem... Vertical is intermittently shrinking after a bit of a warmup, but it sometimes works for longer periods. It folds over and drops to the lower portion of screen and has about 1/4 vertical deflection with the fold over included.
This tv will work for awhile and then snaps to this problem as above described. The chasis has no indications of section identification marking which would help ID the areas I wish to test. If I had a schematic, or repair manual, or even a photo showing where the sections and parts are located it would help me alot. Can someone help me with this difficulty, or schematics, or whatever?
Thank you in advance...
Vito
vitototo2@yahoo.com
352-341-4720
Hernando, Florida
  • 4,234 Answers
Look for the vertical IC. It should be a small flat IC attached to a heatsink and marked something like LA7837. The IC will have a circuit designation like ICxxx. For example IC301. Check all of the caps in the same circuit (C3xx). One or more are bad &/or intermittant. Start there and keep us posted.
Dan
Posted on Apr 28, 2008
Im looking for the manual for my RCA 27V412T
You can view or save your manual from this site to view in PDF or print if so desried.
http://tv.manualsonline.com/manuals/mfg/rca/27v412t.html?idRes=11396722
Apr 02, 2012 | RCA Televison & Video
Color will not adjust on projection tv
From the sounds of it, you have a convergence problem. This can be fixed in the home without too much trouble if you feel you are comfortable with soldering. Can you please post the mdoel number? That way I can provide you with the parts that will need attention. Also please indicate whether or not you wish to attempt this repair yourself. With this additional information I can either guide you through the repair or give you a ballpark cost for the repair.
Thanks,
Dan
Aug 13, 2008 | RCA Televison & Video
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a copy of the schematics for my 9-inch color TV so my husband can fix it.
Well you need to look at the manufacture for this as we do not have diagrams here for TV as there old the newer ones I can find but the older oneswe do not have copies anymore due to the digital conversion.
May 25, 2009 | Televison & Video
Ringing noice from back of tv
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 31, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 27V412T
I repair these for a living and usually this is caused by the "tact switches" (buttons essentially) on the main pcb. This can be fixed easily by someone who is familiar with working with soldering small parts by changing the switches. The problem is most service shops must charge $60-$100 for bench time on a repair like this which is hard to spend with the replacement cost being so low on this product.
Nov 23, 2007 | Televison & Video
RCA Projection TV MM52110 Won't Power Up
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Apr 14, 2007 | RCA MM52110 52" Rear Projection HDTV-Ready...
Televison & Video Logo
517 people viewed this question
Top Televison & Video Experts
