Question about HTC S620 Smartphone
HTC S620 shuts down while I am on a call
My HTC S620 smartphone keeps switching itself off while I am on calls. The battery might still show up as 80% charged, but the phone switches off. I then need to plug in the phone to the charger to restart it. It never shuts down if I have it pluged into the charger. What is the cause of this, and how can i solve it?
  • 3 more comments
  • somarriba Sep 09, 2008
    I have the same problem as described by rogerbiran's, it shuts down while I am on a call or either when I want to hook into a wi-fi hot spot. let me know if this is just a due battery problem.
  • rogerbiran Oct 01, 2008
    I eventually solved this problem by getting a new battery. The problem was directly related to the battery & I think it was caused as a result of me charging the phone over night. I now only charge the phone went required & unplug from the charger when the battery is recharged
  • graphit Oct 29, 2008
    I'm experiencing the same problem. Shut down during call after aprox 3 minutes. In standby, the battery stays on for whole day or longer. Unable to turn phone back on, only when attached to charger. When turned on, the battery indicates still 80% fully charged. Strangely enough, I still own a Qtek 8300 and when I switch my sim card, that phone has the same symptoms. Come on, this cannot be a battery problem ? I suspect the network draining the phone. Sometimes, i can turn the phone on without the charger. It asks me for the pin code but as soon as the antenna symbol appears, the phone turns off. Anyway, i'm tired of all the problems and I'm gonna order a new battery. I'll let you know if it solves my problem.
  • FedeLedesma Nov 18, 2008
    Hi, i have the same problem and i've try with a new battery and the problem persist... i really dont know what to do, im back to mi nokia 1600 :S...
    regrets from argentina!
  • srini215 Nov 30, 2008
    I have the same problem of the phone freezing on a call.I think i have to get a new battery.Same thing happened when i switched to another phone my sim.
You can't use an the "Simplo" batteries. Take the back off & look at the battery. If it says; Simplo Model: EXCA160. Get another battery. Just don't get another Simplo.
Posted on May 01, 2010
Got a new battery & the phone works as good as new now.. Guess it really was the battery
Posted on May 08, 2008
Hi,Can U guys help me to set up the problem of the HTC s620 switch off while the batery is fully charged?
Posted on Oct 01, 2008
  • terrytingote Oct 01, 2008
    the Ideia of buying a new batery is out of mind beacause in my country the authorised company who represent HTC just sell cell phne not the spare
    what a idiot company
Am charging my mobile but when i keep it in the mobile it is showing that the battery is low or empty
Many cell phone used for a long time will met this kind of problems, it seems full charged, but once you are calling someone, the battery power will show empty.
1, mobile phone motherboard leakage lead the current too large.
2, the battery itself is aging.
Try to find out the problems and maybe an external battery can help you a lot
Apr 03, 2013 | HTC Touch P3452 Smartphone
How do i type a word document directly on my htc dash or s620
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Nov 21, 2011 | HTC S620 Smartphone
My g1 wont pass the android screen it turns off automatically and its been charging for 6 hours and it only shows me the red led please help!! Thanks
Try swapping out the battery with a fully charged battery. However, this is most likely a hardware issue with the battery or the phone itself. Try switching the battery first, but if it doesn't work, it will have to be serviced by a technician.
Jan 16, 2011 | HTC G1 Smartphone
I am not able to conntct my htc s620 with my pc
Restart the phone and then try again, See if it charges when you plug in the cable. Make sure it shows some charging symbol on the phone.
If nothing shows up when you plug your HTC S620 on to the computer then your charging port on your HTC Dash needs to be replaced.
Send you phone HTC Dash in for repair to Dr. Cell Phone. They are the largest HTC Repair Service Provider in the US.
Jan 08, 2010 | HTC S620 Smartphone
I need internet and mms settings for htc s620
Hi...
Why don't you call or sms the customer-service of your provider?
they will send you an sms with the settings for the phone.
friendly greetings, Gilbert.
Mar 10, 2009 | HTC S620 Smartphone
NEW BATTERY REQIRED FOR HTC S620 in india
hello i do sell battries but not in india if you do require one pls let me know. i also sell all the other original stuff for pdas and smartphones.
Mar 20, 2008 | HTC S620 Smartphone
Sound switches off
For this u need to format the set & reinstall the software.... it works..
Mar 03, 2008 | HTC S620 Smartphone
HTC S620 Smartphone Logo
487 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
