Question about Dryers
How do i fit a tumble dryer door catch - Dryers
  • Michael Thibodeau May 11, 2010
    do you mean you want to buy one?...or install one?
  • 135 Answers
No reply
Posted on May 01, 2008
Siemens tumble dryer E46.38 no power
if it hasnt tripped a circuit breaker
how old is it
the control board fault
inside the casing and around the drum
some have small sensors with wires
that can be faulty ant stop it heat up and tumble
faulty safety door catch
faulty sealed wall plug
Jun 08, 2016 | Siemens Dryers
How to fit a door catch on a white knight cl 310
Those parts are available and not to hard to replace yourself. You have to remove the door assembly by removing the hinge cover and then the hinge. Then remove the screws that go around the on the inside that hold the outter window frame on. That latch is then accessible to be replaced. Ive included the link for those parts and a picture of what you are dealing with. Crosslee CL310 Tumble Dryer Parts
Dec 15, 2014 | Dryers
Hotpoint condenser dryer door catch
http://www.repairclinic.com/vwo6/Shop-For-Parts/a8/Dryer-Parts
Oct 20, 2014 | Hotpoint Tumble Dryer Door Latch & Catch...
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Jul 19, 2009 | Frigidaire Electric Dryer
Where is the filter/hose supposed to go??????
Hi. Is there a 4" jole that the vent could go in underneath the dryer? Some older model were set up that way. I have never heard of this brand but, it's an idea. Some models were set up to vent out the sides too.
May 20, 2009 | Dryers
Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Dryers
Tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Dec 16, 2008 | Hotpoint NWXR473EV Dryer
How to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Nov 30, 2007 | Dryers
Dryers Logo
102 people viewed this question
Top Dryers Experts
