I have a washing machine that is about 2 1/2 years old when i started a load of wash last night water started leaking out from under it. checked the hoses and there doesnt appear to be a leak in them. any other ideas and iwould it be something I or my husband could take care of or do i have to call a repair person
  • 135 Answers
Depends how handy and ambitious you want to be. :) Easiest thing to do is run another load with a flashlight handy. When you start to see water try to find where it is coming from. Make sure you are not overloading the machine with soap.
Posted on Apr 28, 2008
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
Hello my name is Kevin Singh and i had purchased one of your Bosch Front loading washing machines (model number: wfk2401) probably about 10 years ago i used it last on this last Sunday and it seems to not...
Have you checked the pump and filter are clear? Remove kickplate plinth panel to expose pump. Drain off excess water via small black hose. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Oct 19, 2010 | Bosch Washing Machines
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
