Question about Sony Playstation 3 (PS3) Console
HHD MEMORY My Ps3 keeps saying there is less than 500 MB of memory left, I have dleted all my music and pics, as well as any unneccasary game info, system still says there is only 95MB of 55GB available, I dont know where allthe memory is, I only have 3 games installed on a 60 GB system...HELP
  • 2 more comments
  • shawforc Apr 30, 2008
    Thanks, I had already deleted evrthing after backing up files. I still had no memory. I ended up reformatting the HDD and gained back 47 GB.
  • Anonymous Apr 30, 2008
    The Best way to fix a problem like this is to use a PS3 Repair Guide.
    You can find a good one here:
    www.PS3RepairsGuide.com
  • heads1897 Sep 30, 2008
    i hav similar probem i hav a 40gb Ps3 and only 3 games installed on it which took around 9 gb and i have save files of only one game tht took around 1 mb but still my PS3 shows that i hav only 500 mb of free space
  • 66 Answers
Okay just to tell you the PS3 has 5 gbs already taken up on it.
I think its because the memories of the Saved Files you have on the Ps3 is usually a big amount of room on the PS3. Btw the Ps3 has updates so if you have a low amount of GBs its probably cuz of updates you should have about 48 GB of room left on the Ps3 try deleting the saved Files or try looking at how big the saved Files are.
Your Welcome
I tried my best.
Rate my Solution.
Posted on Apr 29, 2008
Have a 12gb PS3. Why does it indicate not enough memory?
You need storage, not memory. Memory clears out every time your turn the device off.
Oct 22, 2015 | Sony Playstation 3 (PS3) Console
Ps3 keeps saying not enough memory for grand theft auto 5
This means that you only have 3031 mb of memory left, but the game requires that you have 8000 mb, you can get more by deleting games downloaded that you don't play anymore, delete a few and try again.
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
My nokia 5130c-2 is showing not enough phone memory!!! when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about...
Did you save music files on phone memory? If yes , it is time to move it to your memory card. Also check for other big files that still keep in phone memory. If able , just move also your theme files to memory card. Move / delete also old messages files, games (if any), etc in phone memory.
Like computer, your phone need enough space for caching.
Hope this helps.
Regards
Oct 10, 2011 | Nokia 5130 Cellular Phone
I have the 40g hdd with less than 1g memory left. i have no films,vids or music, just game data, but not that much, how do i restore a lot of the space
Okay, to restore the ps3 just put the ps3 off at the back, put it back on, press the power on button and hold down the ps button on the controller, you will be greeted with a menu, just select reformat or restore and voila...
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
Good evening when I start my ps3 with no disc in it it freezes on the begining screen cannot move to ps3 system update or anything to figure out what the issue is I have an original ps3 120gb it stated I...
Sorry, i dont have a solution for the freezing, but, as for freeing up some space; If you have alot off music of videos on there delete them and run them off of a portable USB device (USB key works, but so does and iPod). Do the same with music. Another solution is to delete some of your saved game files. Under the games section on the XMB, there is something called game data or similar to that. Delete some of the files from games you don't play anymore. Also delete game demos you have finished with. These will be located in the very bottom folder under Games. Freeing up some hardrive space may also help with your freezing problem.
Hope this helps,
- Matt
Note - To delete, press triangle and select delete.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My PS3 freezes up shortly after start of game, won't run movies
I believe you may have little or no memory left...
you can upgrade it with a 500 Gb HDD from SATA (2.5' 8or 16" MB Cache make sure it is 5400 RPM ) You can buy it at best buy..
I replaced mine... and it works great now.. when you replace it you can download the software into your external hard drive and transport it back into your ps3..and itll instantly upgrade it for you
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hard drive is saying its full when it shouldn't be
When you install a game it can sometimes install the whole game so theres no loading issues. (e.g grand theft4 3gb ish) if you go into saved game data it should tell you what games are installed, if you hit triangle and select info. it will tell you the size of the file. delete any games you dont use, and dont worry about your saves as they are in the game saves section.
Jan 29, 2009 | Sony Playstation 3 (PS3) Console
Ratchet and clank will not play on my ps3
Get a music CD and put it in the machine, then press the triangle and select import. You may have to use more than one CD to get it to work. There are some files missing that are needed for Ratchet & Clank which are on music CD's.
It worked for me.
Dec 28, 2008 | Sony Ratchet & Clank Future: Tools of...
Sony Playstation 3 (PS3) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
