Lg dvd-hdd rh246 no english manual,having problems with set up, using sky box a picture would help ed
  • Anonymous Apr 17, 2009
    NO RECORDIG DVD
welcomejee
  • 10594 Answers
SOURCE: Sony DVD RDR-HX650 - set up
Sony UK has info how to hook up this unit. Please check there.
Posted on Sep 05, 2008
  • 146 Answers
SOURCE: want to know how to set my LG dvd/hdd player to multi region
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: user manual came with only foreigh language no english
you can get it pdf format from the manufacturers website.
Posted on May 27, 2009
SOURCE: Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Posted on Dec 02, 2009
SOURCE: need hdd nh3t-w55 menual
Has any one got a copy of the NH3T-W55 english manual. I appreciate your kind assistance.
Regards LeDerek@yahoo.com
Posted on Jan 25, 2010
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
I would like to copy some films stored in my sky+ hard drive onto dvds to watch on my portable dvd player. how do I do this?
If you take a scart lead from you sky box and plug it into av2 on you dvd,then select av2 on the dvd as your record channel.Put the sky on play and the dvd on record.hope this helps
Sep 10, 2009 | LG RH177 DVD Recorder/HDD Recorder
LG DVD Recorder RH7800H Manual (need English Language Manual)
Hi. My LG RH1999H HDD/DVD player are unable to play ANY DVD's Is there a setting that I can change?
Aug 03, 2009 | LG Televison & Video
I have a 32in lg tv with one HD input. Also i have a sky hd box. also there is an lg hard drive dvd player/ recorder and also a philips 6510 home cinema player with speakers. what is the best way of...
I would use the Sky box manuals recommendations for connection as this usually gives the best performance especially if you wish to record from Sky to the DVD recorder.
Oct 30, 2008 | Philips Televison & Video
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
Record Blocking Sinals
no codes out ther for this it due to the macrovision reason for the banner you get .
google sky-macrovison -remover ?
riz.
Apr 07, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG RH256 HDD
Follow this link and you will find the manual
http://www.chung-sim.com/lg.rh256.html
Mar 14, 2008 | LG Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
