Question about Neff B1421 Electric Single Oven
Neff cooker model b1422nogb bulb replace
Hi, i,am looking for info on replacing a light bulb in a neff cooker b1422nogb, thank you tony
  • 1 more comment
  • gakdwil Feb 11, 2009
    We have B1442 model and I have tried unscrewing the lamp cover but it only moves a fraction.
    It's glass so how much preasure can you put on it?
    Thanks for any help.
    Geoff
  • Anonymous Feb 18, 2009
    Yes I have the same problem with the bulb it only moves a fraction, I have been told I may ahve to buy a special tool to remove it can anyone enlighten please? Bing.
  • Anonymous Mar 15, 2009
    What if the cover wont unscrew. Like others it twists a bit then is stuck. Tried warm and cold oven.
  • Neff Master
  • 3,463 Answers
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Posted on Feb 10, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
I am trying to replace the bulb on my Neff B1422NOGB oven. The instructions say to unscrew the glass cover anticlockwise. However, the cover only turns by a small amount (maybe just 5 degrees) and...
A common problem with this manufacturer I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it however, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Aug 26, 2011 | Neff B1421 Electric Single Oven
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
Please help Fan not working in Neff U1451
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Feb 08, 2009 | Neff U1721 Double circotherm Electric Oven
Replacement bulb
there are more than one type of bulb for these ovens, the most important thing is that you get one that is rated to withstand temperature of 300oC, or they will shatter with the heat.
Plz rate my solution.
Thanks.
Dec 08, 2008 | Neff U1421 Double circotherm Electric Oven
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff B1421 Electric Single Oven Logo
1,112 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
