Question about Canon EOS Rebel X 35mm SLR Camera
Shutter stuck hey guys, i've had my camera since '01 and it's worked just fine... but i went to take some pics the other day and when i reloaded the film the shutter gets stuck when i take a picture... it closes and takes aaalllooot of time to open again (this was while taking pictures outside in the middle of the day, so lighting shouldn't be a problem). The screen comes up with the message BC... i can't find my manual... can you help??
Not sure about the 'BC', but the shutter problem is most likely due to shutter oil leakage. do you see some shiny black oil on the edges of the shutter blinds? i've had this happen to me once and the repair shop managed to clean it. seems like a problem that bugs Canon EOS cams. Replacing the shutter would most definitely cost more than the value of the camera, so you might want to try this
http://photonotes.org/articles/oily-shutter/
Posted on Apr 28, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
My nikon coolpix s70 camera has a black screen but you can still see playback pics opiton button u just can't see take pics anymore it will flash when u take a pic but its still black please help
Aug 19, 2011 | Nikon Cameras
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
Canon elph 880 can display pic's but can't take a pic,,,,screen remains black and new pics are black
Aug 01, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
When trying to take a pic, I only get a black LCD screen. I can see the icons and I can play pictures back on the review mode. Any idea what's wrong? Thanks!
Try pressing the DISP button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place to save batteries.
That normally fixes the problem of a black screen, but if it didn't, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 02, 2010 | Canon PowerShot SX110 IS Digital Camera
My camera was working fine for about a year. Then one day i turned it on and the screen was black but it shows the grid and date and time also it shows the menu and the differnet scene selections. If i...
Take the camera andturn off the flash. Point it toward you and take a picture. Look in the lens to see if you see the shutter activate. If you dont see this work, then your shutter may very well be stuck.
There isn't really a home fix for it and the cost of having a professional repair it is just as much as a new camera.
If you do see the shutter activate please comment below and I will be more than happy to troubleshoot your problem further!
Cheers!
Feedback is appreciated!
Dec 31, 2009 | Olympus FE-310 Digital Camera
Canon EOS Rebel X 35mm SLR Camera Logo
376 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
