Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
No high spin
Will not high spin
  • crenic May 22, 2008
    Yes, I was in normal cycle. Apparently the drain was stopped up and not draining fast enough or it was a kinked hose because I heard a big gurgle and then it completely opened up and started high spinning. This has been 4 weeks ago and it still works like new!
    Thanks
  • 135 Answers
Make sure you are set for normal cycle. Some permanent press cycles only spin on low. Also check that your drain hose is not kinked. If it is the water may not be draining fast enough.
Posted on Apr 28, 2008
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
No high speed spin
could be the door latch, there is a wax motor in it that closes just for the high spin, if the computer (board) doesnt get that signal it won't go into high spin
Mar 06, 2011 | Frigidaire GLTF1240A Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Dec 30, 2009 | Washing Machines
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Will not high spin
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not going into high spin with any weight in it
I have had the same problem with my front loader. The rug is too heavy and the drum isn't balanced. Try adding more items to the wash and it will spin.
Jan 23, 2008 | Frigidaire FWTBB30DS Front Load Washer
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
