Question about Car Audio & Video
Car audio I recently blew my car amp fuse, which is a 60amp rating which worked fine for months, so i brought a new pack, which consists of 3, and everytime fitted i fitted a new 1, they all blew. one time i kept the bass at minium level and it still blew. I use a 1200 watt mono amp, which powers two 300watt subwoofers. do you know what the problem could be?
  • 631 Answers
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Posted on Apr 29, 2008
Would using a 80 amp fuse instead of a 60 amp fuse in a 1993 Geo Metro cause problems with the starter?
It shouldn't be. The starter is going to pull as many amps as it needs. The fuse is to protect the wiring and keep the car from catching fire in case the starter fails and tried to pull more current than it should. That being said you need to change it back. 80 amps is 33% more current than what that circuit is designed to carry. Being that it's a 1993 you should probably be on your 3rd starter by now
Aug 22, 2016 | 1993 Geo Metro
No power
may be the coil filter choke is wornout...DC supply stage inside your amplifier...go to the nearest electronic tech to repair that..
May 26, 2010 | AudioBahn A1300HCT Car Audio Amplifier
I have a HiFonics 1206D amp and it keeps blowing the main fuse
The 60A fuse is WAY too small!!
The amplifier's Fuse is 80A
You will want the MINIMUM battery fuse @ 80A as well.
Since the current draw at the battery is greater because of the resistance of the wire - an 80A - 100A fuse is recommended.
The purpose of this fuse is to protect your BATTERY if something happens along the length of power wire.
What kind of "shop" are you using?? I would find another one!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Fuse raiting
It's supposed to have two 25 amp fuses.
Nov 13, 2007 | Pioneer GM-X962 Car Audio Amplifier
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
May 22, 2007 | Profile CL1200 Car Audio Amplifier
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
Blowing Fuses
If you disconnect the speaker wires from the amp and the fuse blows only after the remote voltage is applied (when the head unit is switched on), the output transistors are likely shorted.
Nov 14, 2006 | Profile 600MSX Car Audio Amplifier
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
