Question about Microwave Ovens
Mounting a kenmore microwave to wall - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
You can enter your full model number here: http://www.searspartsdirect.com/
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Then look for a "Manage My Home" link on the upper right. That will lead you to a manual.
If you have trouble, please reply back here with your full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
How to remove overhead kenmore 1000 watt microwave
Unplug the power cord and make sure it will come out easily when you start to take out the mounting screws.There are 2 or more screws in the cabinet floor above the microwave. Be ready to catch the microwave once the last screw is removed because it will drop in the front. Then lift the back of the case off the tabs on the wall mount bracket and the whole thing is in your hands.
Sep 23, 2014 | Kenmore 63792 Microwave Oven
I need to know if the kenmore microwave hood combination modle number 02285039000 will be abale to be mounted by using a wall mount only. I do not have an overhead cupboard.
Sorry but you must use the Overhead cupboard.
The wall mount is just for support.
The main wight of the unit is held by the top.
Mar 14, 2013 | Microwave Ovens
I need some help with removing a kenmore microwave hood model # 721.62629200 The release lever that is mentioned in the removal instructions that I have read is no where to be found. Am I over looking
From what I can see online, the microwave is attached to the wall via a mounting plate, so if you lifted the microwave up and out at least the top if not all of the microwave should be released from the mounting plate.
http://www.managemylife.com/mmh/lis_pdf/INSTL/L0903312.pdf
Oct 10, 2012 | Microwave Ovens
How to remove from mounting
if its an under counter set-up,then remove the 2 screws inside the cabinet above the unit and lift out of angle bracket mounted to the wall,use 2 people to be safe when doing so
Apr 15, 2010 | Kenmore 61689 Microwave Oven
How do you mount this model
There are two bolts through the bottom of the upper cabinet that attach to the top of the microwave. These support the front of the microwave. There is a wall plate attached to the wall studs that supports the back. If removing the microwave, take care when removing the front support bolts, as the microwave will fall if not supported when these are removed. There are instructions available at www.sears.com under parts direct. Your model number will be a longer number than you have here it will look like this 000.00000.
Mar 10, 2010 | Kenmore 62702 Microwave Oven
How do i take it down?
If possible, to make the job a LOT EASIER, pull the stove out from the wall, so you can get under the mocrowave.
DISCONNECT THE POWER.
You'll have to remove the unit from the case.
Remove the screws from the bottom and it should slide out. Then, remove the mounting screws. It's best to have a helper, it isn't always in a good position.
May 25, 2009 | Kenmore 63792 Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
How do I install my Kenmore Microwave Oven 721.63664300 to the wall
You can usually find exploded views and order parts & manuals by entering your model number here at the Sears parts site.
Aug 13, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Microwave Ovens Logo
183 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
