Greenish blue vertical lines appear on the monitor of my ibm thinkpad 130. is it time to disacard the laptop (screen costs about 150 pounds)
  • sami28 Apr 28, 2008
    Is it worth spending 150 pounds on it or is too old to invest anything?
    thank you
    Genius:
  • 3,422 Answers
If the thinkpad is under warranty then i suggest you to get it replaced or return it to them and they will repair it up.There are no home remedies to fix it up..
Since the screen costs 150 pounds plus another service charge may also be their to fix it up..It would be better to get a new one with a warranty and make sure you take the warranty extension packs for the new one,once the warranty expires this way it will help you to save alot of money..
Goodluck..
Posted on Apr 28, 2008
  • 1 more comment
  • Priya darshan Apr 28, 2008
    Please don't forget to rate the solution..
    Since your problem is solved can you please accept or rate this solution as fixya..
    Genius:
  • 3,587 Answers
Well..you can run it with an external monitor you know..and extend it's life..otherwise, you'll need to do computer hospice on that unit..
  • Patrick Michaels
    Patrick Michaels Apr 28, 2008
    you may find that moving to a more accessible laptop, like a Sony or Toshiba, will server you better, by the way.
Twenty plus vertical lines in my IBM G40 monitor is there any solutions to clear those lines?
Hi there.
If the line appear from the moment you switch on your Laptop then your screen has gone faulty and will need to be replaced. Other option would be to use external screen.
Regards
Jul 29, 2011 | IBM ThinkPad G40 Notebook
My IBM R52 laptop displays some vertical thin lines (red,green,blue,white,etc). I noticed this problem arises basically IBM R52 and R80 models. Some of my friends too are suffering from this problem and...
This sounds similar to a fault i had with an old dell laptop... very thin vertical lines running the length of the screen. Unfortunately it was an LCD problem, the screen was kaput replacing the screen solved the problem.
To test if it is an LCD fault, simply plug your laptop into an external monitor... if you get no lines on external monitor then its a faulty LCD screen.
Is that solution genuine enough for you?
Aug 27, 2010 | IBM ThinkPad R52 Notebook
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Vertical lines on thinkpad T43p screen.
You have identified the fault is the video card, I am in agreement. The fault is on the motherboard and a replacement motherboard is the only fix. This may not be a cost effective solution, I would recommend you put your money towards a new laptop.
Jun 27, 2009 | IBM ThinkPad T43 Notebook
Turned on and just get vertical lines
if you have tried an external monitor to the laptop and it is still giving the same display then I think that there is something faulty with your vga or display card..Check the manufacturers website and it could be a driver issue but if not then it's time to get a new pc..unless you have the knowledge of going further..Please leave a voting for my help.Many thanks...
Jun 12, 2009 | IBM ThinkPad T30 2366 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 02, 2009 | IBM ThinkPad R51 Notebook
IBM thinkpad T30 Monitor
your sceen is porbably cracked.
bring to a service center nad have it replace.
Oct 29, 2008 | IBM ThinkPad T30 2366 Notebook
Blue line on the screen
Try hooking up an external monitor to the video adapter on your laptop. If the screen appears fine (no blue line) then your video card is good but you laptop's LCD monitor is bad. I would check eBay for a replacement. They are not too difficult to replace if you are somewhat mechanically inclined (can unscrew some screws and disconnect a wire plugged in the motherboard).
hope this helps! : )
Jun 04, 2008 | IBM ThinkPad R52 Notebook
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
