Question about Whirlpool Duet GHW9150P Front Load Washer
LG front loading washer
We purchased a LG front loading washer back in November. Now it will not drain and stops with a E20 warning flashing on the screen. What's going on?!
Kelly
  • Gary Davd
    Gary Davd May 11, 2010
    Kelly first off you need to post your problem under the proper model you look at the top and you have chosen a Whirlpool Duet 9150 not an LG model plus you never gave the model # of your LG so nobody is helping you
  • eric bosman
    eric bosman May 11, 2010
    please give me machine code for the machine
    President:
  • 1,294 Answers
Refer to your manual regarding cleaning your filter
Posted on May 11, 2008
Getting E20 error code on frigidaire front loader. It's 6 years old and has had one main panel board replacement already. Is this the same problem?
You are experiencing a pump issue. Typically a professional is needed to :
1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 28, 2012 | Frigidaire GLTF2940ES Front Load Washer
My washer has stopped it still has water and soap in it OE is flashing on the screen
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
Washer will not empty water all the way & E20 flashes on the screen. What is the problem?
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Jan 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
May 24, 2010 | Frigidaire GLTF2940ES Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
E10 & E20 problem
e10 problems refer to water supply..so check the tap is on, the inlet hose is not kinkrd, and the filter in the inlet hose is not blocked.  e20 refers towater drainage,  so check the drain hose isn't kinked and the drain pump isn't clogged
Aug 09, 2009 | Electrolux EW1000i Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
