Question about Frigidaire Kitchen Ranges
Oven door locks while baking. And oven shuts off and cannot turn it back on.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: GE Profile XL44 Spectra gas oven
Carol, let me see if I can help you with this. First try killing the power to the oven for 30 seconds and see if the locking mech resets. If nothing changes try this: kill the power for at least ten seconds, power back up,simultaneously press the cooking time, delay start and the number 8 pad. Test should appear in the display. Press and hold the self clean key, this will test the lock motor and cam assy. The display should show 2 on the left (for locked) and change to 3 on the left for unlocked. Travel time of the cam will display a 0 between locked and unlocked. You must hold the self clean key for these changes. This latch mechanism is thermally controlled and sends a message to the main board to lock and unlock during self cleaning. We are just bypassing this with this test. Your temperature sensor may have gone bad during the self cleaning cycle. This is the probe located in the oven cavity. If you know anyone that is handy with a meter, it should ohm out at 1092 ohms at room temp. If this checks out, someone will have to open the top and check the lock motor and cam. Catriver..post back.
Posted on Nov 13, 2006
  • 1314 Answers
SOURCE: GE XL44 gas range...door is registreing as locked when it si not
try cancel if that doesnt do it try unplugging it for three mins
Posted on Feb 14, 2008
huuum
  • 750 Answers
SOURCE: I used the self cleaning
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Posted on Oct 02, 2008
jyackle5
  • 8197 Answers
SOURCE: whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Posted on Dec 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Posted on Mar 04, 2009
My kitchenaid range touch pad won't work- no errors displayed, can't turn oven on
careful here. The board needs to be replaced and can cost as much as $300 to $500. Half the cost of a new range. They also have been known to turn on the cleaning mode when baking. Then the oven door locks and cannot get in. Then what ever you have in the oven really gets black and starts a fire. This happened to me a while back. Had to shut off the range breaker and wait til the oven cooled of to open door. Really smelled. Had to buy a new oven because we could not get the burned smell out. I would suggest not to use the oven til new board is installed. Or buy new oven. We bought a AQUALIFT clean oven. It cleans at 250 degrees. Not the high temp of 500 degrees plus.
Dec 31, 2014 | KitchenAid Kitchen Ranges
Electrickitchenaid oven goes on by itself
Common problem here. The board needs to be replaced. Depending on the model, it can cost up to $500 or so. Also when baking they have been know to kick into the cleaning mode. At which time the oven door will lock and the oven gets very hot and can start a fire. This happened to me. Had to shut the oven breaker off. Had to buy a new oven-and not one that cleans with the very hot temps.
Oct 09, 2014 | KitchenAid Kitchen Ranges
Locked Oven Door
You mention shutting off the power. Did you use you circuit breaker to turn off the oven. If not, you should try shutting off power using the circuit breaker. Turn off breaker, wait at least a few minutes, then turn breaker back on. This may reset the oven
Dec 25, 2013 | Electrolux Icon E36DF76GPS Dual Fuel Range...
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
Kenmore 75565 gas oven door is locked. While baking, my son
Had to loosen the lock -- loose enough that the door opened. Only thing that worked. Of course then door wouldn't shut! Cut off the lock and will have to replace.
Feb 10, 2010 | Kenmore Kitchen Ranges
Oven door locks when in bake mode
bad sensor
your range is doing what its designed to do
it is ensing a runaway temp and locking down for sfety at 500 degrees
the sensor is the 3 in tube on the back wall
Sep 22, 2009 | Kitchen Ranges
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
Frigidaire, Gas Oven Door
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Oct 10, 2008 | Frigidaire Gallery GLEFM397DS Electric...
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Welcome to Fixya
Huuum
Oct 02, 2008 | Kitchen Ranges
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
