Question about Brother MFC 8500 All-In-One Laser Printer
Brother MFC-8500 This is my first time using this website. Not sure of the proper order of events I should be taking, but I saw the button under your name on the side of the page. We can receive faxes and the printer says online, but we can't send faxes or make phone calls or do anything that requires pressing any of the buttons. When we press any button on the machine it beeps three times. No error codes are being given. It just refuses to do anything. Any suggestions?
  • mfiller Apr 29, 2008
    Thank you so much for responding. We did unplug the machine yesterday and left if off for a while and then plugged it back in and it is working fine. We had tried that earlier in the day but didn't leave it off long enough apparently.
    Thank you!
  • 487 Answers
What normally helps with brother is unplugging the machine for about an hour and plug it back in.
In your manual says how you can make a test print.
This will clear your internal buffer.
Also it might help un installing the machiine from your network and installing the software new.
try it and let me know what happens
Posted on Apr 28, 2008
2 Suggested Answers
SOURCE: Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Posted on Feb 19, 2009
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 - scanner will not scan
you instal the scaner software properly the solve problem
May 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Brother mfc 8500 printer on xp does not print occasionally.
I try the following-
Unplug your fax machine, wait few seconds, replug.
Open the toner door, take out the unit, put it back in.
Restart the computer.
One of the above should work. It helps me.
Check your printing icon as well.
Apr 20, 2009 | Brother MFC 8500 All-In-One Laser Printer
MFC 8500
The link below should get you the new driver:
MFC 8500 Vista driver
Good luck - I saw some reports of quirky behavior despite the driver update.
Dec 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Jun 20, 2008 | Brother MFC 8500 All-In-One Laser Printer
  2. Select Option 2.
  3. Select Option 1.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Copier not responding
I have misplaced the cd originally purchased with my brother mfc 8500 and I have a new pc . Can't connect the pc to the brother?
Jan 05, 2008 | Brother MFC 8500 All-In-One Laser Printer
Won't scan
Hi there, this problem was posted over a year ago so I boubt you will check this but the best help I ever get is from discussion boards so I think its time to return the favor. I spent 3 hours on this one and finaly figured it out. After following all the steps on solutions.brother.com you need to fully uninstall all brother drivers and reinstall the correct drivers based specifically on your model. In this case mfc 8500. I did this and even went as far as downloading (from above website) the official uninstall tool. I then tried it again and still my driver install would bug at the "click next when connected" But when i connect my printer it doenst let me click next.
Anyways for me the answer to my problem lay in the simple answer of the usb cable i was using. I had a labtop connected to a USB connector conected to a paralell port adapter connected to the printer. I had a theory that the parallel port and usb werent communicating. Keep in mind that the before all this the printer worked fine but the scanner and email fax did not. I then diconected the paralell port from the printer and found a usb entry (weird shape not sure of the term) at the back of the printer. Looked through my cables and sure enough had the usb/weird shape usb cable. Once i connected that to the labtop like a flash everything worked. This was grueling but i hate to admit defeat to computer problems. if you read this..i hope it helps.
Get official uninstall
decompress and use it.
restart. (will not work if you dont)
Get updated driver and software package
Only Connect Usb to labtop now
Only now Turn printer/plug in printer now
Complete instalation
DONE!
Dec 12, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother MFC 8500
Hi, Make sure the rear cover is closed. 2. Usually when you get misc symbols on the printed page the machine couldn't recognize the print job. I would try printing something from another file and see if the problem occurs.
Dec 01, 2007 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
