Question about Alps MD 1000 Thermal Printer
Still no success
Comment by skymail, posted on Apr 28, 2008 I have tried all of what you suggest below and still receive the same results. What would this have to do with the heads? The printer has no problem printing a test sheet. As soon as the paper loads, the file I'm trying to print disappears from the printer's documents.
____________________________________________________
Solution #1 posted on Apr 23, 2008
ginko
Rank: Guru
Rating: 88%, 283 votes
The spooled files are not getting to the printer, do the following in sequence:
Start checking usb cable, test it by using a different one.
Check that no device close to usb can create an electromagnetic disturbance, a power adapter can do this.
Disconnect printer from power, Computer from power (unplug cables form power outlet) and printer from computer for 10 minutes (this will reset printer and get rid of electrostatic charges on PC usb).
Connect everything back and try.
If none of the above worked disconnect printer from usb,
remove printer from 'installed printers' in Windows (or whatever OS you are using)
Reinstall driver from printer disk (printer must remain unplugged).
Plug back printer only when required from printer software or after driver setup.
  • skymail May 22, 2008
    It was working fine before with no other drivers than what came with it. There's no reason it should need any new drivers.
    Sniper:
  • 58 Answers
Ginko:
The MD-1000 is not a USB printer.
Skymail:
Have you downloaded the Alps drivers for the printer? The microsoft driver included in some versions of windows should NEVER be used, it's junk.
Go to http://www.groups.yahoo.com, and search for the Alps group. The drivers are in the files section.
Posted on May 20, 2008
  • fcollingwood
    fcollingwood May 23, 2008
    Skymail.....this is a known problem with the Microsoft drivers supplied with windows.
    If you want to solve the problem, download the Alps drivers from the aforementioned Yahoo mailing list. Since Alps USA ceased support for these printers, and removed the drivers from their website, this is one of the only places to get them. Otherwise keep trying with the M$ drivers, but you will not get ANY joy.
    See here:
    http://forums.microsoft.com/TechNet/Show...PostID=3339537&SiteID=17
  • fcollingwood
    And Skymail....I forgot to add - the Alps drivers will add all sorts of functionality that the microsoft drivers lack, for example Overlay, etc., etc., etc.
    Follow the procedure in the technet link above, and you will be printing again in no time, WITHOUT having to re-install windoze.
  • Alps Master
  • 19,396 Answers
What usualliy happens when is like this is that printer cannot understand the files because either the driver on Windows is not communicating properly with the driver or the file arrive corrupted on begin of file, then printer starts printing blank pages.
Sounds it is the driver or system. If you alredy installed driver properly it could be a Windows fault. Try installing it on a different computer , (install driver BEFORE connecting printer). IF it works, then is a problem with Windows on other computer , in this case you will need to reinstall or fix windows.
In some rare case can be defective printer usb slot. You verify all this connecting to other PC
Posted on Apr 28, 2008
  • Ginko
    Ginko May 22, 2008
    No matters if drivers were working before. Like any other software a device driver can start malfunctioning simply because a windows setting has changed. A device drivers is interfaced with the operative system in a complex way, if windows has a problem a driver may stop working or require an update driver, for example to work along the latest windows update.
    I can only suggest here the general procedure to troubleshoot this kind of problem, that in any case is what I would start doing if I had my hands on your printer.
    Install the printer on a different computer, to ensure that is not a printer fault, does not matter if it prints text page, a fault for example in printer bus will cause the printer permanently staying offline.
    If the printer works on a different computer is the driver that is not working along with windows.
    Try first removing installed printer and reinstalling the driver.
    If this does not work, easiest thing to do is reinstalling windows.
    Regards
  • Ginko
    Ginko May 23, 2008
    You should at least try the suggested solution before using bad rating.
    Inappropriate is used with abusive solution, there was nothing inappropriate in our solution.
    I can see your ingratitude and rudeness to people who are dedicating their personal time to you for free, this is not a game.
    I hope not to deal with you in future.
    Thanks
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
Jan 17, 2016 | Tablets & eReaders
Cannot receive or send picture messages.
FAQ - I cannot send or receive multimedia messages (MMS ...
www.microsoft.com/en.../faq/?...singleTopic&topi...
Microsoft CorporationI cannot send or receive multimedia messages (MMS) on my Lumia phone. Restart your phone with SIM card inserted, and retry sending a multimedia message ...
messaging - MMS sending and receiving pictures no longer ...
windowsphone.stackexchange.com/.../mms-sending-and-receiving-pictur...
Feb 4, 2014 - MMS sending and receiving pictures no longer working on Nokia Lumia. up vote 2 down vote favorite. In early 2014 I installed "Update 3" (8.0.10517.150) and the "Lumia Black" software ... "Can't send message Try again".
Can't send or recieve picture messages - Windows Central Forums
forums.windowscentral.com/nokia-lumia.../299901-cant-send-recieve-pi...
Jul 30, 2014 - 7 posts - ‎5 authors
I have had several friends try to send me a picture message, and i myself have tried tosend a picture message, and i'm just not able to receive ... Not sending Picture messages
Jul 22, 2013
Not able to receive MMS on Nokia Lumia 920 on AT&T
Jul 1, 2013
Can't receive or send MMS
Jun 7, 2013
Cannot Send or Receive MMS (T-Mobile)
Apr 21, 2013
More results from forums.windowscentral.com
Nokia Lumia 930 - Troubleshooting - You can't receive ...
Jan 12, 2016 | Nokia Lumia 930 Smartphone RM-1045
Received a demo unit by mistake. Can it be unlocked?
Amazon.com: Customer Discussions: unlocking demo
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Mar 4, 2014 - unlocking demo ... Can you go into Settings to reset your Kindle Fire? If yes, do the .... Just because someone has a demo unit, does NOT mean it is stolen. Perhaps it .... Receive e-mail when new posts are made. Prompts for ...
[Q] make a live demo unit a full phone - can... ' Samsung Galaxy ...
forum.xda-developers.com/showthread.php?t=1993553
Nov 15, 2012 - 9 posts - ‎8 authors
Hi I get a Note2 Live demo unit on Ebay and I was currious it can be ... The LiveDemo Unit (N7100X on the box) says it has no ... A Case for Unlockable Bootloaders: How Could Everyone Benefit? .... Have you got a link? [ROM][SM-G900X] Custom Firmware for SM-G900X ...
Apr 27, 2014
[Q] Live Demo Unit SM-N9005, Interesting HW ...
Apr 27, 2014
I9505X live demo unit how to recover, instal...
Jul 4, 2013
[Q] Accidentally bought a demo unit, any way ...
Aug 22, 2011
More results from forum.xda-developers.com
Dec 25, 2015 | Audio Players & Recorders
Not printing correctly
That doesn't make any sense either. Canon suggests that you run a deep cleaning three times. Give that a try and if you don't have success use the comment box below to ask me again.
Please remember to rate all out solutions on FixYa.
If this response has fixed your problem please rate it Fixed. If not, ask me what results you have so we can continue to work on a Fix for your problem. Use the comment box below to do this.
Thanks,
Worldvet
Jul 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Motorola L6 Phone not charging or working
Well,
I solved the problem for my L6. IT appears that somehow the phone is software dependent. Meaning that you need to have the Motorola Software for the phone installed in your computer, connect the phone and voila! At least it solved my problem. All of a sudden it charged automatically and I can now charge with the power adapters too. (Yes I too went and bought a different charger, then when it didn;t worked I got a different battery..etc.) just give it a try. I think you can get it for free online somehow, just google it.
Jul 09, 2008 | Motorola Mobility L6 Cellular Phone
Help!!!
so your firmware is good.... it's not the program,, ir's a hardware failure, you dont have signal...dont you have warranty ? co'z if you're going to the service center they are going to repair your parts. and once they do that youre going to loose your warranty. and fix that is expensive too..you might have faulty ( p.a. power ampli, or uem. power and audio ic.. tnx...
Apr 17, 2008 | Motorola Mobility RAZR V3
Want to open internet on my home pc
You can use VPN or Remote desktop through internet with IP address of both system
Apr 14, 2008 | Computers & Internet
Laptop shuts down prox 1 minute into startup.
You can change it by rating his solution as thanks for trying or just denying it.Then rate or accept my solution as fixya.
Apr 04, 2008 | Toshiba Satellite A105 Notebook
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Alps MD 1000 Thermal Printer Logo
141 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
