Clean the small TURBINE filter under the clear plastic housing. If that doesn't work remove the brush assembly and see if the drive is turning. If not, you can easily access the turbine(and gear assembly) to examine components. My $5 flea market unit was not turning the brushes. After removing six screws to access and examine the turbine, and manually get it moving, everything is back to normal.
Hello, their is two reason why the brushes don't spin, one would be the brush brock is broken, take out the brush, and mnake sure their is a plastic two inch shaft sticking out, if not, then the brush block needs to be replaced, if fine, the the turbine is frozen and will need to be replaced, take the lid off and replace the black turbine, I can send you anything you need, or if you have any questions feel free to call 1561-848-3387 Thank you, Teresa.
Clean sweep Vacuums
