Question about GE Kitchen Ranges
Oven is not working; won't preheat or get hot
The burners work. The broiler turns on. I attempted to preheat the oven last night and it never came on. The oven is not working. Does anyone have any idea what the problem is? Ignitor is what someone told me? or could it be something else?
  • whunt62306 Jan 20, 2009
    Same exact problem, will not preheat.. I cant cook now :( and I'm starving!!!! HELP
Called a reepairman who couldn't even figure out how to take the range door off. I called the GE Support Line and they gave me directions on how to take the door off. I ended up paying this guy $137.00 for me to basically do the repair myself ($62 for the part and $75 for labor). The ignitor was replaced. I just hope it will keep working. You smell alot of burning when the oven is on now. The old ignitor had burn spots on the wires as though they had caught fire. The old ignitor also had wire covers and the new ignitor does not have these (wires are exposed and very thin). When I asked the repairman about some other issues. He had no clue as how to respond. Don't call the repairman!!! You can replace the ignitor yourself.
Posted on Apr 29, 2008
Oven & Broiler quit working on same day.
Yes, I think you have the answer. If you have the knowledge, check the electrical supply side, fuse etc. Check out your user manual in the fault finding section. The oven has a thermo switch that prevents the gas opening if theres no ignition.
Apr 17, 2015 | Kitchen Ranges
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
When i turn on my oven it smells like gas
Shut oven off & call the gas company. This is nothing to mess with. Seriously.
Nov 05, 2017 | Frigidaire FGF378AC Gas Kitchen Range
Should my broiler turn on when I am preheating my oven this does not seem right to me and my oven caught on fire last night
Yes the broiler will often turn on to help preheat the oven.
If it caught fire, it is not because of that, but because you have too much run over food in the oven. That is what caught fire. You need to clean it an NOT with the self clean!!
Aug 18, 2010 | Hotpoint Ovens
GE Range...oven problem. Oven turns on but doesn't preheat to set temp. The broiler burner works fine.
Check resistance of lower burner ignitor. Should be above 4ohms. If not, replace. Part 40-75$ + labor. Let me know if info helps- ED
Mar 02, 2010 | GE Ovens
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
