Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Ballast is loose and not connecting to the new lamp . . . Any suggestions?
I tried to replace the bulb and I'm having the problem you mentioned in this post regarding the ballast. It was very loose and not connecting to the new lamp. Also, it seems to have pushed back further into the compartment. Any ideas on how to secure the ballast? I don't want to mess anything up.
    Scholar:
  • 173 Answers
Whats a bulb? whats a ballast?
try calling an expert for I don't even know what you mean.
Posted on May 24, 2008
  • larry hanson
    larry hanson May 24, 2008
    ok seems I,m behind times and an old dieing dinosaur.
    I see bulbs and lamps for sell here.. hope somebody else can clear this up before I re-educate myself.
    sorry
How to replace a ballast in a fluorescent light
Open the light remove ballast go to hardware store get a new replacement. Take pictures so you know how to rewrite it.
Sep 08, 2014 | Philips Ceramalux 1000 W C1000s52...
I have a 8 foot fixture with two lamps and I have tried everything to get it to start up by itself but it wont with out being touched or rubbed to create static.Ive checked connections and new bulbs,...
Some 8-foot fixtures seem to require messing around with the lamps to get them to work. You may have to rotate the lamps back and forth to get a good connection.
Apr 09, 2014 | Sylvania Lamp - 3157A
Replaced lamp broke in Sony KDS-R50XBR1 50" HDTV after 2 minutes
When you say "lamp broke", do you mean the lamp actually physically broke? (as in 'exploded'?)
Was it a Factory replacement bulb, manufactured by Sony? (did it have the Sony logo on the box?) Many "3rd party" lamps are made from inferior materials, made in inferior conditions... and produce inferior results... including what you've mentioned. If this is the case, I suggest getting a replacement, or better a refund, then get a real Sony lamp... personal experience speaking here.
Normal failure mode of the ballast is that it will usually be totally dead, probably 85% of the time. Sometimes you will see one that's struggling to output enough power to maintain proper brightness.
What you describe would be a VERY rare failure, indeed. The ballast can not really burn out the lamp, by design. It's possible the ballast could have been weak, and just now failed... if the lamp still looks to be in good physical condition, this is a possibility, though remote.
BTW... 6 years is pretty good, but it's more about operational hours. I believe those low power lamps should last 5,000 to 8,000 hours, for an original Sony lamp.
Another thing to keep in mind is the lamp cooling. If the fan that cools the lamp has failed, and for some reason the detection circuitry is not realizing that... this could be a problem. These arc lamps operate at about 1200 degrees F (internally), and require a lot of cool air to keep them from literally melting, or exploding.
Nov 06, 2013 | Sony KDS-R50XBR1 50" HDTV
I replace a new Philips bulb on my HL-R7178W and still not light up. It has humming noice (not hi pitch) and clicking like on and off and the Standby/TEMP and LAMP lights flash 2-3 times and turn off. The...
Hello... I would start by getting the correct lamp for the TV, and I would advise getting an original equipment lamp. The lamps and ballasts are matched by wattage and operating voltage, and a mis-match will at best cause early lamp failure. The sound you are hearing could be the ballast trying to ignite a bad lamp caused by a mis-match. I hope this helps!
Nov 25, 2017 | Samsung HL-R7178W 71" HDTV
How do I replace the ballast in an InFocus IN26? And while we're at it, where do I get one? I've already replaced the bulb with a new one (direct from InFocus), reset everything to factory settings, and...
remove the front and rear bezels, remove the top cover, take a picture of the location of screws and ground wire on the metal frame. remove the top boards, remove the metal frame and there is the ballast/power supply. pay attention to the way the cable is routed to the lamp connection, also pay attention to which way the connection from the ballast is seated in the lamp housing. hopefully a new ballast will fix it for you, as to where to get one, that's iffy. you could try to find an in26 on ebay that has other problems but has a working ballast
May 11, 2010 | InFocus IN26 Multimedia Projector
Replaced lamp in toshiba 46hm84. still get
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast is the most common failure besides the lamp.The ballast is the one that displays the lamp indicator if it's not able to power bulb or if bulb is not responding.Have a blessed one!
Mar 30, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Mitsubushi tv model # 52327 ballast replacement
The ballast for the lamp too should be replaced along with the lamp. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Mitsubishi WD-62525 62" Rear Projection...
Trouble shooting Samsung HLN437W DLP
I have sangsun DLP with many point in all picture how canI resolv problem?
Sep 17, 2007 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
294 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
