-   my hotpoint aquarius is so noisy we have to shout over it.having 7 people in house does get used 3 times a day.sounds like plates and cup goin round
-   Guest
Aug 11, 2008
-   Very noisy on spin and drum unstable very worn down ball bearing was lying on the floor underneath the machine once it was moved to check what fell out! - have had to buy a new washing machine after only 2.5 years of use - we are defninately not amused as we are only a two adult household!-   NotoZanussi
Jul 26, 2008
-   When spinning there is a grinding noise that sounds like a bearing failure or the drum grinding on something solid. That is not the thin casing; more substantial.
Only happens on spin.
I plan to replace the barings if i can find a manual to help with the process. If not then it will be trial and error.
the right lower wheel for the dryer drum is a bit loose. looks like it is put on with a pulley press...
(More)
the right lower wheel for the dryer drum is a bit loose. looks like it is put on with a pulley press or something. How can you tighten or replace it
Washer fills with water, but when moving to the wash cycle it just hums. The aggitator does not...
(More)
Washer fills with water, but when moving to the wash cycle it just hums. The aggitator does not move.
