Question about Epson LQ-2180 Dot Matrix Printer
Dot matrix printer is printing dark and clear on the left side of the paper but the print is very light on the right side of the paper?
    Novelist:
  • 110 Answers
Remove and reinstall the ribbon. Also, while the ribbon is out, try spinning the knob on it.
Posted on Aug 22, 2008
Microline 390 printer started printing very light. Replaced the cartridge and the print head still the same problem. Will print some areas dark and some are so light you can bairly see it. Any ideas?
Dot matrix printheads go bad, can be rebuilt, never had great luck cleaning, pins get stuck out.. Also there is a lever that moves the printhead closer or farther from paper. make sure that is in the right position. Usually on top cover may have numbers by the lever such as 1 , 2 , 3 etc
Nov 08, 2016 | OKI MICROLINE® 390 FB Printer
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Epson lx - 300+ ii borderless
If you know how to set the margin to 0.00, just set it and send a print-job. You will see what happens.
Oct 31, 2013 | Epson LX-300+ II Matrix Printer
Okidata 186 does not feed
Are you using pin feed or friction feed? Make sure the lever on the right is in the correct position.
Apr 08, 2013 | OKIDATA - DOT MATRIX New - Oki Microline...
Printing quality is very poor
The print quality of dat matrix printers depends upon the printer ribbon. If the ribbon is old or worn out then the print will be very light. In this case replace the ribbon.
Dot matrix printers are very old technology and I suggest you get a Inkjet printer or a laser printer.
Dot matrix printers cannot match the print quality of Inkjet and laser printers.
Jun 04, 2010 | Office Equipment & Supplies
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
Aug 20, 2009 | Absolute Software ComputraceComplete for...
Prints one side faded one sige legible the other side as if the printhead has a problem
Epson Dot matrix DFX 8000
Due to printer head firing is not proper.
The Prnter need servicing and once serviced it will be alright.
Sometimes the Printer Ribbon might have not rotating and the print will not be visible on the left and at right side it is bright.
Better consult the local printer hardware enigneer and settle this iseeu.
Put the original and best gsm paper in the printer, when prining job is iniated.
Jul 20, 2009 | Epson DFX 8000 Matrix Printer
Unable to do a reverse line feed
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Apr 12, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson DFX-9000 dot matrix printer not printing far right column
It probably is a margin setting. Can you try printing on a blank w-2 and preview it before printing. That way you should be able to adjust the margin as needed.
Jul 30, 2017 | Epson DFX-9000 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
300 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
