Printer sharp ar-m155.keep showing me replace toner cartrige.i changed it but same problem.printer is warming up too long, than showing replace toner cartrige.
  • 6 more comments
  • delu Apr 29, 2008
    i forgot to tell you about the corotron. was broken.i replaced it,but the same story.
  • delu Apr 29, 2008
    sharp ar-m155.working ok but after 30-40 pages half of the page was blurry.i refilled the cartrige.after i puted back the printer start warming too long and after 3-4 min. message:replace toner cartrige.i cheked the printer and i found the transfer corotron broken. i replaced.no improvements. can you help me?
  • delu Apr 30, 2008
    yes ,but no improvements
  • delu Apr 30, 2008
    sharp ar-m155 all in one.i had the corotron wire broken.after this,when i start the printer is warming too long,and displaying replace toner cartrige.(toner cartrige was refilled)
  • delu Apr 30, 2008
    the bulb inside the thermal tube working
  • delu Apr 30, 2008
  • delu May 01, 2008
    the printer is 3 years old.the corotron wire is on a small door.maybe i was broken it trying to close the door.i replaced it with 70 micron corona wire.
  • delu May 01, 2008
    sharp ar-m155 all in one.i had the corotron wire broken.after this,when i start the printer is warming too long,and displaying replace toner cartrige.(toner cartrige was refilled)the printer is 3 years old.the corotron wire is on a small door.maybe i was broken it trying to close the door.i replaced it with 70 micron corona wire.
    Brigadier General:
  • 6,966 Answers
with the indulgence of the others....
Pls recheck how the micron corona wire is attached to the printer, it may be corroded and therefore would require scrapping/cleaning. Additionally, is it the same gauge/size as the original/old wire?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 01, 2008
    Brigadier General:
  • 3,614 Answers
How old is your printer..?
how did you damage that coroton wire.. have you done replacing it or you just fix it...?
Thanks
Posted on Apr 30, 2008
    Master:
  • 377 Answers
Yah.. could be the thermal tube got a fault..
    Genius:
  • 3,587 Answers
How old is the printer..this sounds like an end of cycle failure mode for your Sharp unit.
Pat the Printer man
Posted on Apr 29, 2008
    President:
  • 1,944 Answers
Did you try disconnecting from the power for 10 minutes?
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
My Sharp Ar-M155 is displaying d message replace the toner cartridge. I ve tested d cartridge with another machine and it is working perfectly
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 07, 2011 | Sharp Office Equipment & Supplies
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
May 03, 2008 | Office Equipment & Supplies
123 people viewed this question
k24674
jasbo
jasbo
