Question about Brother DCP-8020D All-In-One Laser Printer
Brother DCP8020D Document Feeder
Soulvisitor - Thanks for your good advice on the document feeding problems with Brother printers. I have inspected my left hinge and I don't think it's the problem. When you first insert a page in the doc feeder, the machine spins up, sucks in the page about 1/2 inch and then the ERROR light comes on. So I'm more inclined to think that the problem is with the Document Pickup/Feed Roller assembly. Would you agree? Should I replace other parts as well (rubber separation pad, LF roller assembly, etc.)? Thanks! - Dave Claunch in Austin, Texas
  • Brother Master
  • 1,113 Answers
Clean rubber rollers with metho, run a page by hand of laminate or stiff card threw the doc feeder. Stick it where the paper comes out of DF and ensure path is clear.
Push down on left side or tape down little black switch (rear left corner near glass)while trying to use df to confirm hinge aint the issue
If it is the rollers it should feed when paper is "helped a little" with hand at feed time
Ensure prints ok when using glass instead of df to know it is df problem
Cheers
Posted on May 08, 2008
Will not manually feed paper
Are you talking about the document feeder or the copier. On both counts try to clean the rubber wheels above the feed tray, or up on the document feeder with something like windex or a water cleaner. make sure the wheels are dry, and watch to see if the wheels are turning. If wheels are turning when you feed you need new wheels, sometimes you can rough them up with a grit nail file, or sandpaper.
Apr 30, 2014 | Brother MFC-8460N All-In-One Printer
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Document Feeder won't work
hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
Apr 15, 2008 | Office Equipment & Supplies
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother DCP-8020D All-In-One Laser Printer Logo
123 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
