Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, My buffalo external HDD power supply seems to have died. So i connected the external HDD directly to my PC via IDE cables. My PC recognized the connected external HDD but didn't boot and ended up freezing in the black screen. Does it mean I need to install OS in the connected hard drive? Does new OS installation will erase all data in the hard drive?
Tomislav Marinovic
Level 2:
  • Expert 205 Answers
  • Posted on Aug 10, 2010
Tomislav Marinovic
Expert
Level 2:
Answers
205
Questions
0
Helped
77213
Points
569
Set your bios to boot from your normal drive, not the ide buffalo drive ...
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Code error 10 device refuse to start
used how? PC or MAC?
running the encryption way?
Most fast external HDD have a power pack.
20watts is typical to run any fast drive. they suck 2amps at start up.
so power is king, if not good power, the HDD can be destroyed.
say , using the wrong pack.
some slower HDD use laptop slug HDD< they use very little
power and some dont even need a power pack,
i looked on newegg, yours is the slug kind,
is USB3 too.
but some systems can not produces USB power, too good.
This is a common issues with using over 500mA on the USB buss. and for SURE must be plugged directly into the PC
and never a USB hub (RTM)
try you unit on other PC and Laptops.
it has special cable too. that can be damaged.
so try all USB ports directly to the system
then using your ear, press it to case side, HDD.
is it whirling? , no, then there is no power to it, or its dead.
easy that, huh?
try it on another system.
the led color , reasons are in the manual. red,green, blue.
error code 10,what did that come from?
and last the horses mouth
http://en.faq.buffalo-global.com/app/answers/detail/a_id/11884/p/1492,1493
1helpful
2answers
Popular issues: problem with Buffalo Technology (HD-CE500IU2) 500 GB USB 2.0 Hard Drive My laptop is no longer recognizing the Buffalo External Hard Drive. When I plug in the USB to my laptop,
HI guys, I found a solution to a similar problem with the buffalo portable HDD that I brought from my friend. I just changed the HDD cable with the cable from Western Digital My Passport HDD and all problems were sorted out. Physically the WD cable is bit thicker than the Buffalo HDD cable. So suspect the cable is the problem. Please check if this is the problem with your Buffalo HDD before formatting. All the best
Indrajit Pande
I can't find my hard drive. Where is is?
1) Depends on whether you are using an external or internal Hard disk drive
2) If it is external HDD, ensure that the USB cable is plugged into the PC for auto connectivity
3) If it is an internal HDD, You have to unscrew your metal case, look for the 3.5 inches in rectangular dimension metal device screwed onto your CPU casing. Ensure that there is a physical cable connection between the HDD to the Motherboard. The cable that will direct you to the HDD from the Motherboard should either be the SATA (Small Flat headed Red cable) or the IDE cable (white flat 24 pin cable)
On the HDD brand label there should be a Capacity size in MB or GB or TB, Cylinders, Heads and ensure that the poswer supply is connected to the HDD if it is an IDE HDD
My external hdd from bytec is not recognized by my computer. What shall I do?
Try to use direct connection to your computer. Using IDE cable.
If your comp can detect, means your external casing problem.
If not detect, your hard disk problem
3helpful
2answers
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
2answers
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
