Blue Screen Issue
I have a Yamaha 5.1 surround sound receiver (don't know model) connected to a Mitsubishi 50" rear projection TV. I have Cox cable. Issue: when watching cable channels, screen indiscriminately goes to blue screen (with sound OK). When I briefly power off the TV and power back on, it stops the blue screen and picture is restored but, it continues to happen. Funny thing is, I can watch DVDs and the problem does not occur. I've had Cox out and they have shown me that the BER on the cable box is very low and the signal strength is within tolerances.
What should I be looking at?
  • 78 Answers
Try hooking all systems involved to the same electrical circuit, using a power strip if neccessary. also check your big screen and other equipment and make sure that any polarized plugs are in correctly. if you are an electrician, or know one, check the circuits that you're using to be sure the outlets are wired correctly. if the ground, neutral or power are not wired to the outlets properly it will seem to work, but not right. check the "cable line in" at the ground block with a multimeter for excessive power or get a qualified cable tech to check. when you touch the cable coming to the box or the tv and also touch the cable in do you feel a tingle? if so, it is most likely a power issue as mentioned above.
Posted on Apr 30, 2008
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
Mitsubishi projection tv display does not turn on
unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Hi, I connected internet cable (was just experimenting whether cox internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after...
LOL!!!!!!!!, your tuner is now faulty and maybe your Microprocessor as well, you will have to take it to a repairer this something you wont be able to solve sorry ......
No sound
I suppose you have a surround sound system that is now not functioning? They must have disconnected your audio out cables from your television to your surround sound system. Make sure your main audio out channel on your television is connected to AV1 in on your surround sound system. It is probably an RCA cable (red and white). Then when you play your TV, make sure the audio is set on AV1 for your surround sound system by pressing the function button until AV1 is on the display. Let me know if this helps.
Dec 26, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
