Printing The yellow and magenta toner in my oki printer are finished. How can I print with just the cyan or black. Hope to hear from you soon.
    Scholar:
  • 60 Answers
Most of the time, CMYK printers only work in conjunction of one another. If one cartridge is missing, it will require all of the missing or empty cartridges be replaced.
So, you'll need to purchase some more ink.
-Ernest
Posted on May 01, 2008
Please I have an oki printer C831 that's printing only yellow and black on any printing am using it to print please help
I would think you have broken ribbons cables to the cyan and magenta LED print heads. As all the heads are the same I suggest you swop the black and cyan print heads around and see if cyan prints and black does not. That will prove is the print heads are ok. If they are then the ribbon cables need replacing or they are dirty at the heads. It could be just a case of unplugging them, clean them, then plug them back in again.
Oct 21, 2017 | OKI Office Equipment & Supplies
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Magenta LED head appears broken
What you need to do is power off the machine. Open the top cover and look at the Magenta LED print head. At the right end there is a white flat ribbon cable plugged into it. Pull out the cable and let it dangle BEHIND the print head. Close the cover and power up. You will hear no motors and eventually you will get a fatal error 13x. Power OFF and push the cable back into the head after wiping the back of it with your fingers. Be careful and make sure it goes in straight. If happy and it looks like the other three then power up again. You should hear the motors once again and all should be well. If you still hear nothing then turn off immediately and follow the instructions again. If you get it wrong then you may have shorted out the control board which renders the machine useless. You do this at your own peril. It usually cures all its problems. good luck
Mar 30, 2017 | OKI C5150n Led Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:support@compudesk.in
Jul 14, 2009 | HP Color LaserJet 2600n Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Faint repeating
I have problem with my Phaser 6130 Laser Printer, I changed toners (black, cyan, magenta yellow). My printer printing only cyan and magenta, colors black and red is very, very light. I cleaned my printer exactly. Everything is ok, but he does not has a black & magenta toners. What's happen? I don't know.
Donna
Jan 30, 2009 | Office Equipment & Supplies
Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Feb 15, 2008 | OKI C9500dxn Led Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
