Question about Nikon COOLPIX L2 Digital Camera
Camera won't accept an SD Memory Card anymore
My Nikon Coolpix L2 camera won't accept an SD Memory Card anymore. We've tried inserting a new card and get the same error: This card can not be used. The memory card is not locked. What do you think?
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
Coolpix s8100 technical support my camera dropped and broke so I was given a replacement. When I insert memory card from other camera and try to take pics, a message reads, "file contaisn no image...
First, get a card reader (they're very cheap) and use it to download the pics from the card. Then, re-insert the card into the camera and go into the menu and find "format"....follow the on-screen instructions to completely erase the card and optimize it for your new camera.
Oct 15, 2011 | Nikon COOLPIX L18 Digital Camera
I am having nikon coolpix L18 camera, it is working with internal memory card. When i inserted external memory card, it display "this card can not be used". I checked ext memory card in another...
Your camera supports SD HC, multimediacard and SD memory cards, is that card of a different type? you will get this problem if the card is of too large capacity too, your camera ,might have an upper limit for supported memory capacities.
May 02, 2011 | Nikon COOLPIX L18 Digital Camera
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
My Coolpix 4600 won't work with an SD card
once you insert the card you have to go into your menu and reformat the card. reformating will erase its contents so keep that in mind.
Oct 25, 2009 | Nikon Coolpix 4600 Digital Camera
How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Aug 09, 2009 | Nikon Coolpix 4100 Digital Camera
4gb not compatable?
camera wont accept a 4gb card most only take 2 gb sd cards .
Jun 03, 2009 | Nikon Coolpix 5000 Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
Nikon 5700
Thanks! I'll give that a shot.
Jul 14, 2008 | Nikon Coolpix 4600 Digital Camera
Error: This card can not be used
Greetings Qstorm92,
My guess is that the card is locked. There is a small lock on the side of the card that can sometimes accidentally slide to the lock position. Try checking this and see if this fixes your problem.
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 28, 2008 | Nikon COOLPIX L2 Digital Camera
Nikon COOLPIX L2 Digital Camera Logo
168 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
