Icant get it to print anything cartiages are full and it goes though the process like its printing but paper is blank
  • 85 Answers
Hello windymejia4,
Try these things. 1. is the tape still covering cartidges? Take off and try to print? 2. Is the right print drve picked? control panel, printer , make sure your printer is picked as defualt. 3. did you allow printer to do alignment? 4. see if ink will smug your finger with ink, when one of the cartdges is taken out? If not use a pencil eraser and erase the mental tip where ink is suppose to come out? Is this a fixya?
Posted on Apr 28, 2008
Epson stylus photo rx585
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 11, 2013 | Epson Stylus Photo RX600 All-In-One InkJet...
Lexmark A940 (AIO) - The cartiage is showing
1. The cartridge may be dried up.
2. The cartridge contacts in the printer may be damaged.
3. Mechanical interference prevents print heads from moving.
If your cartridges are rather new but have not been used recently (a few weeks or so), they may be dried up. You can test this by removing one cartridge and applying rubbing alcohol to the nozzles. Let it sit this way for a few seconds and put it back into the printer. If your test page shows some streaks instead of nothing, that is your problem.
Open the printer cover. If the print cartridges move to the correct location for replacement, there is not mechanical interference. If the motors make noise but the cartridges do not move, there may be an obstruction in the printer. Try to clear it.
If neither of these are the case, try replacing the cartridges with genuine Lexmark cartridges certified for your printer. If this does not remedy the situation, your printer's contacts or other components are damaged. In this case replace the printer.
Jan 24, 2010 | Dell A940 All-In-One InkJet Printer
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
Prints blank pages
check if there is still ink in the cartridge.also use a soft cloth and little water to clean the nozle of the cartridge.
Jul 02, 2009 | Epson Stylus C62 InkJet Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Hi, i have an epson R200. ink levels are all fine. it goes to print and goes through alkl the actions but paper comes out blank? can you help
I have the same problem ... ink is full (New) but won't print, although it seems to think it is printing. I've gone through the clean process, but no result.
Jan 23, 2009 | Epson Stylus Photo R200 InkJet Printer
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
90 people viewed this question
k24674
