Question about Adobe Photoshop 7.0 for PC
Need to change backgroud color of photo - Adobe Photoshop 7.0 for PC
This really depends on what the background looks like. In all of these cases, however, a good tip is to copy the background layer so that you have a duplicate layer to work upon. This way you can always mask off some of the top layer if you go too far, or mess up too badly, without losing all your work.
That being said, the first step is to select the background. You might try to start with the magic wand if the background is easy to tell from the foreground. Make sure to check/uncheck "Contiguous" if all of the background pieces are or are touching. Also adjust the sensivity of the majik wand (it goes from 0 to 255. 255 is going to select everything, so I'd start with a tolerance of maybe 50 and go from there.)
If the background tends to merge seamlessly, you can try to select the background with the Lasso tool. Just start draggine the lasso tool along the background that you will want to change. You can take it in small chunks as long as you hold down the "shift" key when you start your next selection.
Once you have the background of the photo selected, a good idea is often to make the selection just a little bit blurry so that when you change the color the borders won't be too abrubt which tends to look a bit jarring and unreal.
A good way to do this is "feathering" the selection by 5 or 10 pixels (depending on the size and resolution of your photo).
To do this SELECT>FEATHER and choose between 5 or 10 as your feather radius.
Then on to the final step, changing the color of the background.
I'd tend to use IMAGE>ADJUST>HUE/SATURATION.
Once you have the Hue/Saturation dialog box up, click on the "colorize" button and make sure the "preview" button is also checked.
I usually start by increasing the "saturation" slider, this allows more color into the selection, and enables you to see the effects of the top slider, "Hue"
Slide the "Hue" slider until you get the approximate color you want the background of the photo to be. You can then use the middle slider to add more or less of that hue, and the bottom slider to adjust the lightness and darkeness.
Hope this helped,
Philip
Posted on Apr 30, 2008
Change Photos from Black and White to Coloured
Unless you want to colorize them by hand, there's no way to add color to black and white photos. Given a black and white photo showing a person in a gray dress, how do you know whether the dress was blue or red or some other color?
Dec 18, 2012 | Fujifilm Finepix S4200 Digital Camera
Hi, I have a Canon iRC3080i printer and want to replace all of the drums on it myself. Need to know how to rotate the drums from the console once i have done the replacement and clear the count...
the drum units isn't on the "rotary drum". To change them you need to pull out the drum holder out, which is behind the toner hoppers and beneath the transfer belt.. Its difficult to explain by the words, for installation manual send me the mail on emma.servis@gmail.com.
Apr 26, 2011 | Office Equipment & Supplies
My dektop backgroud is blurry
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Dec 06, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
In layout all my lines becomes appers in white
Hi, go to options -> display -> colors -> on 2d model space -> uniforme backgroud -> choose the color black in the left
May 23, 2010 | Autodesk AutoCAD 2007
How do i change the background on my acer ten inch laptop?
right click on screen as in your desktop and click on properties or personalize and there you find you option of desktop backgroud
You can change it according to your need
May 17, 2010 | Computers & Internet
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
My printer copy's in color but prints photos in black and white,
Check your settings for your printer software program, change it to black and white, and then you will need to change it back to color, if you want to print in color.
Aug 10, 2009 | Office Equipment & Supplies
Digital pictures: want to add background with my G2 & Photoshop L
First you need to "cut" kiten out using the lasso tool, the quick selection tool, or the magic wand and delete the remainder of the picture by hitting the delete key, then you can put the picture of the kiten on any backgroud you choose.
Mar 18, 2009 | Adobe Photoshop Elements 6: Windows
Adobe Photoshop 7.0 for PC Logo
76 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
