Question about Canon Cameras
Cannon 5 D, Shuttle want work, when putting the battery in the red light want come on. Top display shows information. I change the time and date battery, I also took both batteries out to reset. Nothing
I packed it up and mailed it to a service company.
Posted on Apr 29, 2008
How to set the time and date
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Oct 25, 2010 | Nortel T7316E 2-Line Corded Phone
Change time and date on Norstar M7324
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Oct 25, 2010 | NorStar M7324 Telephone
My phone shows the wrong time and date, how do I reprogram it (I have no manual) sorry, its a Nortel Networks NT8B27JAAA..
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
Jan 05, 2010 | Lands Phones
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Oct 06, 2009 | IBM 6400 Matrix Printer
Changed battery on roberts r871 radio .time date needs to be set
hold down mode button until display flashes, change time with up/down buttons. Press mode button once to change to date use up/down to move through dates, the time display will show year you are in the further you press the up button the further in the future you will scroll. This radio holds date & day information depending on the year displayed. Leave flashing to time out after adjusting.
Apr 27, 2009 | Emerson Audio Players & Recorders
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
Set time & date on Cannon P100-DH II
Press the Date and Time button, when you see the date on the display screen, then press = and hold, you will see the first number blinking, then just type in the numbers (day - month - year) it moves along as you type, when you are done, press = for 1 sec the date is now set. Now to set the time press the Date and Time button again, you will see the time showing on the display, press and hold = until the firs number starts blinking, then proceed to type in the time, when you are done, press = for 1 sec the numbers are supposed to stop blinking. the date and time is set, then clear your screen (press CE/C) the date and time are saved.
Feb 19, 2008 | Office Equipment & Supplies
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
Cameras Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
