Question about Brother MFC 8500 All-In-One Laser Printer
How do i get my printer to print a legal size copy
I am having trouble copying a legal size document, it cuts it off as a letter size.
Thank you:)
  • 487 Answers
In your printer settings as you hit print
select the printer setting prefferences
select paper size( change from letter to legal) and your problem is solved
When you copy through the software program from brother you can change this in there. Just redo the prefferences.
Posted on Apr 28, 2008
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
How can i copy a legal size document on the Epson Stylus CX9400?
Take a photo with digital camera. I am doing this on newspaper articles from books at local Historical Society then cropping and other editing in my Serif Photo Plus 11 program.
good luck,
LindaC in OK
Jan 28, 2009 | Epson Stylus CX9400 Photo Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Brother MFC 8500 All-In-One Laser Printer Logo
813 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
