Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto expresso machine is producing thin, watery and cold coffee. I have walked through some troubleshooting with a Saeco rep and no better results. The top warming plate stays hot. Water flows easily and it drops "cakes" of coffee and all parts are free of coffee grinds.
  • 487 Answers
It sounds like the heatingellement of the boiler is broken.Pump works. you also , if i am right get no hot water if you try that.
You can get the part on line. which will be cheaper than doing it through saeco
Try this link SAECO PARTS
Placing it is not too hard as long as you work methodical.
Posted on Apr 30, 2008
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
Prime indicator always flashing after 3 seconds (saeco incanto classic)
sounds like thermostats...are shot..will need a model number to help you out.
Mar 10, 2008 | Saeco Incanto Coffee Maker
How to get less water dispensed. My expresso dispenses 100ml. Too much for an expresso. Help.
On a lot of machines if you press and hold the button while it dispenses and release the button only when you have the desired amount it will retain that amount for the next button press of that particular button.
Jul 23, 2014 | Saeco Incanto Classic Fully Automatic...
Coffe is too watery, and pucks are very loose
Try adjusting the grind finer. You have to do this while the grinder is running, Try 2 numbers towards fine. Then you will have to brew 2 coffees to get a reading on your adjustment.
Mar 02, 2011 | Saeco Incanto Classic Espresso Machine
How do you stop the water leaking on the Incanto Model of Saeco Expresso maker?
Likely an issue with steaming valve,. They wear out every year with regular use. They can be fixed easily by service guy.
Nov 20, 2010 | Saeco Incanto Classic Espresso Machine
Wasted espresso
Check the chamber under the valve, make sure that it is not filled with coffee grounds and water, also there is a small discharge chute under the chamber to the drain tray make sure that is clear.
Sep 12, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Coffee cold
Your model has 2 boilers, it is possible that the coffee boiler thermostats have tripped, or the element is damaged.
Jun 04, 2009 | Saeco Incanto Classic Espresso Machine
Descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Cold coffee, machine does not go through warm up cycle
I think its the main element that has a fuse thats need to be reset.
There is 2 kinds of elements on this machine one for the steam and one for the coffe.
On the main element there is 2 automatic fuses that you can reset by just clicking on them.
Jun 28, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
274 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
