Washer leaking I detemined the water is leaking out the bottom of my washer. How do I remove the panel on the bottom to take a closer look?
  • 5 more comments
  • sherrijn Apr 28, 2008
    Amana LWA50AW - I need to remove the bottom panel so I can take a closer look
    Amana LWA50AW
    That would be great - thanks.
    yes
    I can't find where I rate your response to my problem :(
    I have figured it out - thanks for your help. I won't need the manual
    I'd like to rate coolguy for his help as an A+++
    Genius:
  • 3,422 Answers
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 28, 2008
  • 5 more comments
  • Priya darshan Apr 28, 2008
    Can you please give the make and the model no. so that i can find a service manual for it
    Hi again,
    I have got the service manual do you want the link?Actually i would have given it to you but you have already rated another expert's solution.If you need then let me know and please accept my solution as fixed for this.
    Waiting for your reply..
    Was that comment for me?
    ok,Can you please accept my solution as fixed for this and another thing since the service manual is not available for free download you will have to pay$16 for that..
    Let me know..
    ok,no problem..If you don't mind wat can you please send an email to experts@fixya.com about this issue and even i'll send one to them..
    another thing can you let me know whose solution helped the most in this one..
    Please CLICK HERE
    Please CLICK HERE for the service manual in case you need it..
    I am glad to hear that your problem is solved..
    Thank you for using fixya..
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
Can you give us first the maker & the model part # of the washer..
Thanks
  • 5 more comments
  • micromaster
    micromaster Apr 28, 2008
    kindly wait i'll find schematics for that model..
    Thank you
  • micromaster
    as i see you have one contact over here.. until i still finding for the diagram please let me know if his solution fix the problem,
  • micromaster
    are you sure it was LWA50AW...?
  • micromaster
    this for an initial post which can give you a guide..
    click here.
    Please input again the model of the washer..
    Thank you
  • micromaster
    Look@ this...
    Click hier..
    Cheers
  • micromaster
    it's free...!
  • micromaster
    Post back how things get done...
    I'll park in here.
    Thanks
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Leaking water
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
Aug 14, 2010 | Frigidaire FWSB5700DS Top Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaking in on the left side of the washer on bottom
you can remve the lower acess panel (3 screws along teh bottome front panel) too look to see where it coming from. the top also removes with 3 screws along the top of back panel
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana washer leaking during spin cycle
Solution solved - THANKS for all the help
Apr 28, 2008 | Washing Machines
Leaking
This machine has two removable front panels. At the bottom of the unit are two (2) 10mm bolts. Removing these bolts will give you access to the working parts since this is an inspection plate, The upper panel : There are two (2) 10mm bolts located at the bottom corners. Remove these bolts, pull the bottom of the panel toward you to release the top latches. This will give you full access to see where the water is coming from. I suspect a leaking pump but cannot rule out a bad tub seal.
Jan 08, 2008 | Maytag SAV515DE Top Load Washer
My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
