Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
My machine is leaking during
posted by sherrijn on Apr 28, 2008
My machine is leaking during the spin cycle - from under the washer
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Provided by LOGITECH STAFF
Best Solution
posted on Apr 28, 2008
FixYa! (100)
IrishDruid
STAFF
Rank:Guru Guru
Rating: 87%, 921 votes
Hello sherrijn,
It sounds like a leaking drain hose or a rusty / broken tub. It could also be a problem with the stem or seal kit or the bearing kit being broken. Its really hard to say without actually taking a proper look.
Well, based on my long distance evaluation, I'd say that rust is most likely the culprit. The underside of the washing machine is the most inaccessible part, and is often ignored while cleaning, etc. It can tend to get rusty pretty quick. This can cause the metal to disintegrate/fracture easily and cause leaks.
However, having said that, inspect what you can and see if you can find an obvious source of leaking. You can try to cover that up temporarily with duct tape or a sealing agent. But for a proper fix, I'd recommend you get a qualified technician to take a closer inspection.
Hope that helps!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If, however it has not, then please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best as I can.
Thank you for using FIXYA!
Cheers!
IrishDruid
Rating Locked! (?) sherrijn has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My machine is leaking during:
I don't want to Accept this solution
Provided by SANDISK STAFF
Solution #2
Not Rated (0)
computerrep
STAFF
Rank:Guru Guru
Rating: 88%, 505 votes
I would recommend you to try taking the back panel off of the machine, (make sure its unplugged first) under the drum you will see a short black rubber hose with jubilee type clips holding it on, it may have come loose during a spin, you will need a different type of screwdriver to undo it, like a hexagon type,
hope that helps!
Thank you
Computerrrep
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
Not Rated (0)
coolguy008
Rank:Wiz Wiz
Rating: 84%, 260 votes
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Goodluck,
Please don't forget to rate the solution
Thank You!
Can you Help with these Washing Machines problems?
Washing Machines
i have a bosch washer dryer wvti 2840, have put some...
Washing Machines
the washer cycle beep signal is very much lower/softer...
Washing Machines
Maytag wringer washer. Pad you stand on to make the...
Whirlpool Duet 3.8 cu. ft. Capacity Front...
Every time you put your clothes in the washer, pull your...
Whirlpool Duet GHW9150P Front Load Washer
All other functions, including agitate and drain, are...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
