Printer stuck I have been using this printer for several years. I have replaced the cartridges many times in the past. When I replaced a new color cartridge, now I am getting this message aligning Please wait, but nothing happens. I never had this problem before.
    President:
  • 2,712 Answers
Hi ra78,
Did you go through the link I posted in my comments?
It gives very thorough troubleshooting tips, and its written by the folks at HP themselves ;) Also, I would recommend that you download and reinstall the drivers after uninstalling the older ones. Make sure you do not plug in the printer until the software asks you to.
Remember to use a fresh, white sheet of paper!
Do these steps and get back to me on the progress. I'm here at your service:)
Cheers!
Posted on Apr 28, 2008
  • Swilin Sampson
    Swilin Sampson Apr 28, 2008
    Just wanted to inquire as to how its going...Any luck?
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    Thank you for using FIXYA!
    IrishDruid
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
ESP-9 will not recognize new cartridge
2 things to discount first
1. Are you using a new Kodak cartridge, Kodak like other printer suppliers use a recognition chip in there cartridge in an attempt to get past the refillers, try a genuine replacement cartridge
2. Is it possible that more than one cartridge needs replacement, this will also throw up the same message
If the answer to both these are No contact the supplier of the cartridge and inform them of the trouble or contact Kodak directly
More info
http://wwwbe.kodak.com/global/en/service/publications/urg00977toc.jhtml?pq-path=13658/14011
Sep 15, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Printer will not work after installing a new ink cartridge?
did you see a piece of plastic stuck on the back of your cartridge?
Mar 21, 2009 | Lexmark C533DN InkJet Printer
Color of pictures
image quality occuring after long period of inactivity of the printer oftenis caused by inks drying up or clogging either the nozzle or the channels of your printhead. to prevent this from happeniong, i suggest you do the maintenance first: deep clean and calibrate the printhead before you start using it if you havent used it for quite a while. you might be experiencing a printhead problem if the printer is printing predominantly in one color. you should try to visit thsi helpful website. the link ive provided below:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
it should direct you to the right recourse regarding your issue...hope this helps..ciao!!
Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error message "Color cartridge missing"
sounds like you got one with a faulty chip, take this back to where you got it from and they should replace without any problems.
Oct 05, 2008 | Dell 924 All-in-One InkJet Printer
Printer reads RIGHT CARTRIDGE INCORRECT
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
Printer Error
I fixed this problem by installing a new magenta ink cartrige. This makes me believe the problem is in the replacement cartridges. Of course this is not very satisfying because I had to discard a 3/4 full ink cartridge.
Oct 16, 2007 | Canon Pixma MP800 All-In-One InkJet...
71 people viewed this question
jasbo
jasbo
