Question about Nikon COOLPIX L2 Digital Camera
Error: This card can not be used
My camera won't accept the SD Memory Card anymore. We've tried inserting a new card and get the same error: This card can not be used. Is there any way to fix this?
  • Qstorm92 Apr 28, 2008
    Camera being a Nikon Cool Pix L2..sorry about aht!
    Nope card isn't locked. I've tried that too. Thanks for trying. :o)
    Novelist:
    Champion:
  • 216 Answers
Greetings Qstorm92,
My guess is that the card is locked. There is a small lock on the side of the card that can sometimes accidentally slide to the lock position. Try checking this and see if this fixes your problem.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on Apr 28, 2008
3 Suggested Answers
  • 306 Answers
SOURCE: konica revio kd-400z camera memory
Maybe your memory card is full
Posted on Oct 10, 2008
lock123
  • 6831 Answers
SOURCE: Camera won't accept an SD Memory Card anymore
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
Card Error
possible too big of a card . in memory capacity
Mar 29, 2015 | Cameras
My Panasonic DMC-FZ20 says Memory Card Error.
Hi
Please check your cameras capability to support larger sized SD cards.It may not support those two SD cards.Also check for slide locks on the side of the cards and slide them to 'open' before inserting.
Hope it helps.Thanks!
Feb 18, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
My Kodak EasyShare V530, won't accept a memory card, you insert a memory card, and it doesn't even acknowledge that there is a memory card inserted.
I bet the memory card that you're inserting is a brand new 4GB SDHC card (your camera can only use 2GB or less standard SD cards). There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Apr 10, 2011 | Kodak EasyShare V530 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Jun 07, 2010 | Kodak EasyShare C310 Digital Camera
Does the Fuji FinePix F45fd camera accept 4Gig SDHC cards?
I had the same situation.. I also bought memory card (4 GB) and my camera came up with an error...Maybe this card is not suitable for finepix F45f?
Dec 30, 2008 | Fuji FinePix F45FD Digital Camera
Hello
Kind regards
Andrea
Apr 28, 2008 | Nikon COOLPIX L2 Digital Camera
Nikon COOLPIX L2 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
