Have aBosch Nexxt 500 which has a leak coming from the bottom of the unit. Seems to be leaking regardless of being used or not.
  • 487 Answers
If it is leaking without being used it has to do with the line prior to the primary valve.
open it up and follow the waterline leading into your machine. It can be a simple as a ring being lose.
or your valve might be broken
Posted on Apr 28, 2008
I have a Bosch front loader washer. It has begun leaking water out of the bottom, and often will not run through a full cycle, but we sometimes get lucky. I tried it today and 5 mins into the cycle it...
You have to inspect water outlet from the drum. When it starts filling water, water leaking out at the same time. So computer sees, thet water level is not going up, so it stops. You should call service, or if you have someone, who ca open and see. Some times you can find it yourselves
Dec 02, 2017 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Leaking from bottom
Are you sure its not leaking at the top? in any case
call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
