How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
    President:
  • 1,796 Answers
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Posted on Aug 10, 2010
SOURCE:
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Jan 01, 2011 | Heating & Cooling
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
Dear sir, The denon AVR 3300 receiver quits after playing a while; somtimes it quits after an hour,sometimes after 2 hours! Can you tell me how the sleep timer functions..... Thank you Cees van...
There is no sleep timer on the 3300. You are experiencing an "over heat" shut down. The 3300 is notorious for over heating at almost any volume level. It must be vented constantly with an external fan pulling air completely through the cabinet. Don't use it at all until you do this. The internal fan is week and will start to make noise from too much heat. Replacing the Denon fan will not solve this either. See my other posts about this issue.
Oct 03, 2010 | Denon AVR-3300 Receiver
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
Kfr 24w condensor will not run
Check the contactor to see if the contacts are stuck or welded together, if not check to see if you have 24 volts to the contactor, if you do then the thermostat is not opening.
May 17, 2009 | Comfort-Aire BHD-301 Dehumidifier
Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Jan 05, 2009 | Heating & Cooling
Sleep function?
Yes this model does have a sleep timer. It's under the timer menu. Here is a link to the Manual
Jan 05, 2009 | Panasonic CT-27SF25 27" TV
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
