Question about Samsung ML2250 Laser Printer
Fusor error when i print this message pops up - fusor error,usb001on my notebook
  • vlekkie Apr 28, 2008
    thank you for the great advice ,and fast response eric, i am actually afrikaans speaking close to nederlands /flemmish speach,i am a frensman.good luck and thanks again
    marius
  • majuseje2008 Mar 02, 2009
    tengo una impresora multifuncional samsung scx-4521F Y no quiere imprimir en la pantallita sale error del fusor
  • 487 Answers
According to your name I almost an convinved you are from Holland? heb ik gelijk?
This links will give you the answers you need. I guess it is an installation problem which will need for you to un install and re install your drivers.
otherwise it might be the fusor fan which is stuck which requiers you to clean it.
please try this link and if it helps please rate me as FIXYA.
Groetjes Eric
Posted on Apr 28, 2008
You need to replaced your fuser or checked the sensor on the fuser.
juses
Model 2820. How do I solve engine error?
Try Engine test:
turn on device open tray 1 and load paper (1 is the manual feeder)
when you open tray 1 there's an engine-test switch, found it and press it
Engine error are also cause too much resistance from toner, fusor or gears. Remove toner and check that it roll with your fingers on gears, and do same with fusor (could be very hot warning - should be hard move it but not too much) and with printer off and fusor removed check if you can move any gear manually (this can be harder but will help you determine if it's board error or resistance cause a gear problem).
Any previous error happened with the printer can help to diagnose (jams, power off while printing...)
Sep 17, 2015 | HP LaserJet Office Equipment & Supplies
50 fusor error code for hp 3055 copier printer
Fusor needs to be replaced or error in Fusor section of main board
Jun 01, 2015 | HP Office Equipment & Supplies
50.2 fusor error
Hi Zaikow,
Whats the printers model?
Still, check the fuser and make sure its well held in place by the two tabs otherwise if the tabs are loose,the error will appear.
Hope this helps.Thanks!
Nov 25, 2011 | Office Equipment & Supplies
Mi impresor Konica minolta me da error c3721 quiero que me ayuden porfavor
You need replace the fuser. Is a fuser overheat condition. You can reset but the error repeat.
Before replace the fuser, I recommend you do upgrade the firmware.
Este es un problema común del fusor de estos equipos.
Tu necesitas reemplazar el fusor. Es un problema de sobrecalentamiento. Puedes resetear el equipo pero el problema se repíte hasta que cambies el fusor.
Antes de reemplazar el fusro, te recomiendo actualizar el firmware del equipo.
Si esta información te fue útil, agradecer no está de más.Y dar unos puntos y calificación
Sep 16, 2011 | Computers & Internet
When printing or copying the ink can be rubbed off, this is usually down the middle of the paper. Any idea which part is at fault, jets, imaging drum ?
This is a problem with the fusor not heating in the middle for some reason. Either the fusor roller is damaged or the heating element is.
Toner is not like ink, it has to be heated onto the paper.
Take a good look at the roller...if it's not damaged, then the fusor itself has a problem and the unit in either case must be serviced.
Feb 23, 2011 | HP LaserJet 2840 Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Samsung ML2250 Laser Printer Logo
591 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
