Question about Rimage Media Kit for Everest II, 1,000 White 8X DVD-R, CMY Thermal Ribbon (210744002)
Mp3 channels Is there a way to check if mp3 file was saved in Stereo or Joint mode?
  • 207 Answers
Open folder where your mp3 files are saved, right click on column bar, click on More, and check channels.
Posted on Apr 28, 2008
How to convert a videos
Launch your video converter program if you have one.
If you do not have a video converter program, consider free programs such as AVC Video Converter
Prism Video Converter
These programs are cross-platform applications, compatible with both Windows and Mac OS X operating systems.
Click "Add Files" or "Add Video," depending on the program that you are using.
Locate the video file you want to convert from the folder you saved it in, then click "Open" to import it to the video converter program.
Play your video on the monitor to ensure that it is the video that you want to convert.
Select the video format you want to convert your video to in the "Output format" or "Profile" window.
Choose from a number of video formats, such as MP4, AVI, MOV or WMV. Different models of MP3 players use different video formats, so refer to your MP3 player's documentation for the compatible format.
Select the output video size you want to use. Video sizes vary with different MP3 players. Some MP3 players support 320x240, while others support 640x480.
Refer to your MP3 player's documentation for the supported video size.
Select the audio codec that you want to use for your output video file.
Some of the most common audio formats include MP3, WMA, AAC and WAV.
Audio codecs compress audio with different output quality settings, so refer to your MP3 player's documentation for the supported audio codec.
Select 2 or "Stereo" in the channels box for a balanced left and right audio output.
Click "Browse" and select the folder where you want to save the output video.
Select a folder or location that you will be able to remember and access quickly.
Click "Convert/Encode" to begin the video conversion process.
A status bar displays the progress of the conversion.
When the process is finished, your video is in the format that you selected
hope this helps
Sep 27, 2012 | Audio Players & Recorders
Why is my akai advd51 not playing music
Please check the format of file you are flaying from USB device if it is one of these supported by your system.MP3-CD
Dolby Digital, MP3, PCM, WMA.If it is correct try to set the audio settings to simulated stereo or stereo out.Your system is a 5.1 system so it is possible that all channels will not be simulated with a stereo source.
May 26, 2012 | Music
Solam MP3 SL800E
How to use
1. Save your MP3 or WMA files into the car MP3 player directly from your computer.
2. Insert the 12 ~ 24V adaptor end of the car MP3 player into your vehicle's cigarette lighter
3. Choose you preferred frequency on your MP3 player, and then adjust your FM radio' s frequency same to the MP3's.
You should have received a user manual with your mp3 player, please read the manual, as with these chinese devices, we don't have the manuals to write down the instructions for you.
Jan 17, 2010 | Audio Players & Recorders
My panasonic SC-AK87 dolby prologic, surround mode and 5.1 chanel didn't work. Just radio fm can work/ Help me!
the out put is common to all channels, only that sounds are thickened or lighted by adding components like capacitors and resistors.
open your set and check for a dry joint on the channel which is not working
dont forget to check the cables, not having cuts
Apr 27, 2009 | Yamaha NS-A60X Main / Stereo Speaker
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
I can only put 127 songs on my player and the package says up to 500, what am I doing wrong?
when they manufacture any unit such as yours they base the amount of storage according to an average size of mp3, most likely a 3 min song with minimal Layer-3 storaACM, 44100 Hz, 96 kbps, joint stereo files. if the files you are saving are larger than this , then they will take upto double and triple the space.
Mar 18, 2009 | GPX MW-3805 MP3 Player
I cannot get the functions on the remote to pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Uploading files into projects
Most of the time you have to convert the wav files to another format Such as MP3 or WMP. there are converters available for this purpose online.Google audio converters. Maybe you will find one that you can afford . Or even find freeware.
Oct 28, 2008 | Zoom H4 Handy Recorder
Reseting my Sansa Media Player
you have to light a joint then go to recovery mode and then go to shut the *******
Sep 15, 2008 | SanDisk Sansa e250 MP3 Player
1. In Menu scroll down to Setup
2. In Setup scroll down to USB Mode
3. In USB Mode there are 2 settings MSC Mode & MTP Mode, check or highlight
MSC Mode. This enables the PC to recognize the player as a removable
Device or Drive.
4. Connect to PC via USB port/cable, the PC now reads the device as
MP-C70X5 (E:)
5. In WIN Explorer click “Open to View Files”, on display will be 6 .DIR folders
& a .xml file
6. Now launch the VideoConvert.exe (application file) located on the
installation disk.
7. Click Input Video button (Browse to the folder containing .avi files) & select
.avi file for .mtv conversion
(if you want to save the .mtv file to a different destination folder click the folder
icon to the right of the Video Output text box).
8. In Output Frame Size box check 176X144 (this is the max size for this
9. In Output Frame Rate box check Sports Video.
10. The Output Audio Quality box defaults to Good.
11. Click Start Conversion button.
12. The saved .mtv file can now be copied to the device by simply dragging
from its destination folder or ctrl + C & ctrl + V to the MOVIE.DIR folder in
WIN Explorer as per step 5.
13 The .mtv file is now saved to the device ready for viewing, however there is
just one remaining small lissue which may a software glich or another hassle
with this player, because when the video is playing, every 60 seconds in the
background a womans voice exclaims what sounds like “Weeee Gamble
whatsup with that.
Jun 23, 2008 | Coby MP-C7085 MP3 Player
Electronics - Others Logo
66 people viewed this question
Top Rimage Electronics - Others Experts
Are you a Rimage Electronics - Other Expert? Answer questions, earn points and help others
