I just started up my laptop and stuff, but when i started the Freecom 250GB external hard drive its making strange sounds and now its switching its light on and off, i can't use it either. Its about 3/4 years old and i think i over used it (70GB is occupied on it) but i still need it.
  • ascarona Apr 29, 2008
    its not working on another laptop either, i used all USB ports. My laptop aint that old, its about 3-4 years or something but lately it has been shutting off, you know, suddenly without doing anything. The only thing that isn't working is the Freecom external hard drive/3.5/USB 2.0. the manual said something about not exposing the hard drive to shocks, does the whole "laptop suddenly shutting off" have anything to do with it?
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    Try to use it on another computer and see if it works fine on it. Chances are (hopefully) that the external is just not getting enough juice from the USB port. How old is the lap top? Do you have problems with any other hardware on the usb drives?
  • 62 Answers
Ok then it is the HD, you can take it in to a computer store and have them save the information off of the drive. You can also go to the manufactures web site and see what the waranty is like on the HD also, you may be able to get a new one to replace the defective one. But first and fore-most, go into the closest circit city and see about getting the information saved onto another hard disc.
Posted on Apr 29, 2008
I am trying to transfer all my photos from my old freecom external HD to a new external HD, but the Freecom keeps switching itself off mid transfer, every few minutes. I'm worried I'm going to
sounds like a faulty drive, afraid without sending it off only way you will be able to get info off is by transfering it bit by bit,
best u use cut files at least u dont have to keep copying same files over and over that way
Jun 16, 2012 | Freecom Computers & Internet
Data Missing from 250GB Freecom HardDrive.
May be that is hidden..Go to the control pannel look for folder options and then in the view tab check the box show all files and then click ok.
connect it again see if are able to see your files again. if not then there are data recovery tools available on the internet.
But i think the first method will solve your problem
Jul 28, 2010 | Freecom (24358) 160 GB Network Hard Drive
Says 4gb not 250gb.
It sounds like your OS (windows XP+, I presume, as it's NTFS) is reading the wrong partition information from the hard disk.
Use this (free) partition software to delete all partitions on the external drive (and make VERY sure that it's pointing at the external, and not your main hard disk!).
http://www.partition-tool.com/personal.htm
...so delete all partitions; make a new one and see if that is 250 GB.
If yes, format.  Sorted.
If no, you could try editing the partition table directly with this:
ftp://ftp.symantec.com/public/english_us_canada/tools/pq/utilities/PTEDIT32.zip
...you'll again have to be careful you're working on the right hard disk.  To use this, you'll need to know the number of heads, cylinders etc.  This data might be on a label on the disk (inside the external drive case), or you might be able to get it from the disk's manufacturer; either on their website or by emailing their tech support.
If editing the partition table doesn't work, or if the numbers keep reverting/changing, then it's highly likely that the hard disk is stuffed.  Only thing to do then is replace the hard disk in the external case (make sure you swap for the same type: IDE for IDE and SATA for SATA); or explore your warranty options.
Hope that helped.  Good luck!
Mar 03, 2010 | Freecom (24358) 160 GB Network Hard Drive
Mac cant read files on an old external drive
Evidently, MAC and Windows are not compatible. All you need to do is to download and install a software for your MAC to handle file/s from Windows. Thank you.
Oct 06, 2009 | Computers & Internet
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
http://www.freecom.com/ecsupportdetail.asp?serie=Mobile+Hard+Drives&group=1148826&interface=1148827
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
It does`t show on my computer and make sounds
bought a new external hard drive two days ago, freecom 1tb, moved bout 300gig of stuff on to it as soon as i got it home, the next day when i plugged it back in my computer would not reconginse it, checked my computer, disk management and device manager, still nothing. it just makes a constant beeping noise now when plugged in, whats wrong wit it and what do i do to fix this problem?
Mar 20, 2009 | Computers & Internet
My computer USB drive is not picking up my new freecom mobile drive (250gb). Im running on WindowsXP. The drivers for the drive are not being installed and the device is not recognised when connected to...
Hi
Try this Link out to solve your problem...You need to install its driver and restart your window...
http://drivers.softpedia.com/progDownload/Freecom-USB-Driver-Download-17392.html
Good Luck
Genius Guy
Oct 16, 2008 | Computers & Internet
Problem to start my external packard bell usb 2.0 250 GB hard drive
Sounds like the drive is dying. Is it externally powered, or powered through the USB port? How old is the drive? When you say 'strange' what does it sound like?
Jan 08, 2008 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
