Toner light will not go off
Added new toner and the light will not go off. don't know what to do. Model is a Ricoh FT 3713.
  • 1,326 Answers
Did you remove the tape from the toner bottle when you installed it? It may just be looking to add toner back to the developer, to bring it back to the set level of toner? See if it stops
Posted on Apr 30, 2008
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 28, 2015 | Ricoh Office Equipment & Supplies
Ricoh mP 2018D Giving " adding toner "message always
that what it does to let you know that its adding toner
Apr 04, 2015 | Ricoh Office Equipment & Supplies
How do i add developer toa ricoh ft 3713?
Vac and clean the developing unit then replace the developer
but if the case is developer spilling we need to replace the 4 bushings and seal then replace the developer
Aug 22, 2011 | Ricoh FT3713 Copier
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Ricoh Toner for FT3313 and FT3713
When the developer is the same the toner is the same.The toner drops in to the developer,thus the toner must be the same.They just package it different to be a pain!
Nov 20, 2008 | Ricoh FT3713 Copier
RICOH COPYING MACHINE MODEL 3713
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Aug 24, 2008 | Ricoh Office Equipment & Supplies
Ricoh Ft 3713 Toner light still on
try to enter 65 or 66 and let it free run for bout 20 copies...after that switch it off then on again...u can make it a try.
Jun 24, 2008 | Office Equipment & Supplies
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
Added new toner but light won't go off. Ricoh FT 3713
The TD sensor got disconnected or is broken, the copier needs service because it's not detecting that it actually has enough toner inside to copy.
Apr 30, 2008 | Office Equipment & Supplies
Ricoh ft 4618
Did you run the copier with out adding toner for awhile? If so, it is going to have to catch up with the toner level it had before or it may need a developer change. The toner level may be to low to regain it's amout of toner again. It may be a coastly venture with running the copier with out toner.. Good Luck...
Apr 29, 2008 | Office Equipment & Supplies
100 people viewed this question
k24674
jasbo
jasbo
