Question about HP PSC 1510 All-In-One InkJet Printer
Paper wont feed
The paper will only feed in if i give it a lilte guidence if i dont the printer will say im out of paper what can i do
  • 62 Answers
Printer needs a service: Paper feed rollers are dirty and can't pick the paper up
Posted on May 11, 2008
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
Message on printer printer calibration load plain
Well this is simple but iratating
There are paper feed from begining to end Im gonna say this is a manuel to static printer this is simple in the sense that you do not need to really do anything accept keep it clean. When you drop the paper in the printer you need too let feed dont stick it in there let it sit in the carrier and the printer should grab it if not You may have gotten a lemmon Take it back and tell them HEY IM NO ******!!!!!!!! You know that
Oct 18, 2009 | HP PhotoSmart 7960 InkJet Printer
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Feed paper light stays on, and paper doesn't feed through
hi im josh in cebu phils. friend if it stays lighted on and cartrdge move side to side. ther problem is in your paper feeder it wont detec the paper because maybe it is already covered with dirt and dust. try to clean it. good lcuk
Feb 23, 2009 | HP DeskJet 970cse InkJet Printer
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Paper wont feed from tray
Sounds as if you need new rollers on your printer. I am not sure what the cost would be on this. Some are very easy to install - they just stick over the old ones.
Mar 30, 2008 | Office Equipment & Supplies
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
